fitment question?
Old Feb 13, 2007 | 02:17 AM
jdmjazz's Avatar
fitment question?
Will these rims slap right onto the (P195 / 55 R15 84H) stock tires on the stock 15' sport alloys ?
15x7 4x100 38 offset
15x6.5 4x100 40 offset
15x7.5 4x100 38 offset
Help will be appreciated
Old Feb 13, 2007 | 02:14 PM
towelie's Avatar
iHardpark
yea they should but i think their gonna be a lil fatter
Old Feb 13, 2007 | 04:00 PM
milano sol's Avatar
yes.
as long as you have a 15" rim you should be fine. are you sure the rims are 15x7.5? im not syaing they dont exsist either....just typical 15's are 15x6.5 and 15x7 in terms of aftermarket rims.
if in fact you do have a 15x7.5 rim check to make sure the 195 tire will fit properly (they should considering the sidewall is 55 and youll get a slightly stretched look)
fyi i have 15x6.5 +40 rims with BFG tires in 195/55-15 having the rims push out a lil more with the offset help the balance and handling of the car.
Old Feb 13, 2007 | 04:53 PM
jdmjazz's Avatar
Originally Posted by milano sol
yes.
thanks for your info =)
Yes I am sure they are 15x7.5
BigWheels.Net: custom wheels,chrome wheels,alloy wheels,car wheels,truck wheels,aftermarket wheels,large rims,wheel and tire packages,polished wheels
They caught my eye.
So do you think these rims will work perfectly with the stock 195/55-15's ?
Old Feb 17, 2007 | 01:20 PM
b17gsr's Avatar
I'd be worried about a rim that wide with that offset. The wheels will stick out about 1.5" more than stock, and will rub like mad if you lower it.
using a 195 tire on a 7.5" rim would look funny.
Old Feb 17, 2007 | 03:20 PM
spoonek4's Avatar
IMO...
195/55 on 15x6.5, 205/50 on 15x7 are perfect match.
195/55 on 15x7 will fit but u will end up using the outter edge of the tire a lot especially if u drive it hard. Anything smaller than 195/55 is not recommended on 15x7.
195/55 tire will stretch like crazy on 15x7.5.....
If I can find a set of nice 15x6.5" then I will sell my 15x7" rims for sure. 15x7 worked out great on my EM1 SiR before but I think 15x6.5 is a better match on the GD3.
Muster
Jun 24, 2011 06:02 PM
jonno86
Sep 20, 2009 08:31 PM
Ciggy
May 8, 2008 09:38 PM
nate9
Feb 20, 2006 03:35 AM
