Re: Strange ongoing humming tone from 94 Accord
Old May 4, 2005 | 11:16 AM
Abeness
Guest
Posts: n/a
R. P. wrote:
> "Abeness" <news@nada.x> wrote:
>> Well, do remember that your power lock mechanisms will burn out much
>> faster by leaving that unfixed. Then you could have to open ALL the
>> door panels instead of just the driver's...
> You might be right though I think it should have done that already in
> all this years.
Guess Honda makes good shit!
R. P.
Guest
Posts: n/a
Beats making bad shit. ;-)
In any case, I re-read the text on that Web page I pointed out earlier
and then I checked my copy of the official Honda Service Manual of that
model and was surprised to see that there was no BLU/WHT wire there
behind the door panel at all. Then I was also confused by the seemingly
conflicting solution of the problem. First the author suggested that
the solution was the grounding of that BLU/WHT wire:
"I asked him to ground that BLU/WHT wire. The locks stayed in the lock
position and stopped trying to re-lock themselves. The control unit
needed to see that lock switch input wire from the driver's door lock
actuator go to ground and when it didn't see it, the control unit kept
trying to lock the doors. When the lock input wire was grounded, the
control unit was happy and the locks stayed locked."
Then he ends up by another, more expensive solution: "The technician
solved the problem by replacing the door lock actuator."
So what am I missing here?
Rudy
Abeness
Guest
Posts: n/a
<snip>
Sorry, Rudy, I can't be sure. My own understanding from a quick read of
that post is that a ground on that wire is normally a momentary
situation that tells the actuator that the door is locked, so that it
stops trying to lock the door. Permanently grounding that wire may
therefore prevent the actuator from functioning properly under normal
conditions--it might never try to lock even when unlocked because it
thinks it's already locked due to the ground.
Since I don't have any experience with this issue, I hope someone else
will respond.
R. P.
Guest
Posts: n/a
> of that post is that a ground on that wire is normally a momentary
> will respond.
That's all right. I'll talk about to my mechanic at my next
scheduled maint. visit. In the meantime I wish I could figure out how to
secure the left roof top rubber trim so the automatic car wash machine
does not tear it down every time I visit there. If anybody has any
ideas, let me know.
Rudy
csrbob
Guest
Posts: n/a
Door lock actuator problem
Thanks for the post guys I have the same problem on my 94 Accord. I
purchased a door lock control modual from my local junk yard. It did seem
to improbe the problem. However didn't fix it. The post with the blu/wht
wire was ok. Still need to focus on the wiring what ever color that is
connected on the drivers side door lock. I have connected and disconnected
the wires. I am going to follow the wires. Tomorrow. I'll look at any wires
in the driver door that are near the key lock. Thanks for the post. I'll
add more to it and will be as spacific as possible. Oh the Dealer wanted
$70 for new, $25 for junk yard modual??? csrbob
andrew416
May 21, 2008 06:52 PM
letsgoff
Sep 20, 2005 01:37 AM
Dick
Jul 21, 2005 07:31 PM
ONECABINETMAN
Jun 27, 2005 08:22 AM
skipper
May 18, 2005 02:25 AM
