seatbelt indicator.....
Old May 4, 2005 | 11:16 AM
Howard Lester
Guest
Posts: n/a
Re: seatbelt indicator.....
"andrew416" wrote
> I have an 04 Honda accord. Is there any way to disengage the seatbelt
> buzzer??????
Yes! Fasten the seat belt, preferably around your upper pelvic region.
(Translation: here we go again.)
TCS
Guest
Posts: n/a
On Tue, 1 Mar 2005 19:36:34 -0500, RTG <rtg@mailinator.com> wrote:
>"disallow" <loewen_t at yahoo.ca @> wrote in message
>news:55cdd8b8e31818ca49da664cd913d4df@localhost.t alkaboutautos.com...
>> fuck you punk, bring it on.
>whats going on here ?
It's that time of the month.
RTG
Guest
Posts: n/a
news:55cdd8b8e31818ca49da664cd913d4df@localhost.ta lkaboutautos.com...
Abeness
Guest
Posts: n/a
TCS wrote:
> Give the twit a break. He used up half his vocabulary and you expect him
> to handle the grammar as the same time?
Naw, TCS, I think this is a puerile exchange and wanted to lighten
things up a bit. It was a joke.
TCS
Guest
Posts: n/a
On Sat, 19 Feb 2005 20:48:12 -0500, Abeness <news@nada.x> wrote:
>Uh, you left out the comma after "you", dude.
Abeness
Guest
Posts: n/a
disallow
Guest
Posts: n/a
TCS
Guest
Posts: n/a
On Fri, 18 Feb 2005 16:24:37 -0500, disallow <> wrote:
>you started it bitch.
Don't make me come over there, brat.
disallow
Guest
Posts: n/a
TCS
Guest
Posts: n/a
On Fri, 18 Feb 2005 14:21:44 -0500, disallow <> wrote:
>maybe you should RTFSM, it says wear your seatbelt.
Maybe you should SYFBH.
The shop manual is not the owner manual, moron.
Sten-Arne Zerpe
Guest
Posts: n/a
On Thu, 17 Feb 2005 15:14:23 -0500.
In the Newsgroup(s): rec.autos.makers.honda
With the Message-ID: <0a679dbae5d148696ec5fde10d6762c2@localhost.talkab outautos.com>
And the Organization Header: www.talkaboutautos.com.
The famous author: "andrew416" <robinbuilders@netzero.com>.
Wrote on the subject: seatbelt indicator.....:
>buzzer??????
Yup, buckle up buddy.
disallow
Guest
Posts: n/a
TeGGer®
Guest
Posts: n/a
"andrew416" <robinbuilders@netzero.com> wrote in
news:0a679dbae5d148696ec5fde10d6762c2@localhost.ta lkaboutautos.com:
> buzzer??????
Whoo... This used to be easy in the Old Days.
These days (and your car is probably very similar to my '91 Integra in this
regard), the functions of the key-in-door-open, seat belt buzzer, etc., are
all handled by an Integrated Control Unit, behind the driver's side kick
panel in Civic-based vehicles, and probably in Accords as well.
That ICU has a small piezo-electric beeper, identical to those used on
computer motherboards and modems. That's what makes the annoying noises.
Basically, if you disable one audible warning, you disable them all, which
is exactly what I did with my Integra. The way I did it is amazingly crude:
a #8 wood screw, tightened by hand through the hole in the plastic housing
of the beeper component. The screw presses against the beeper's metal
diaphragm and prevents it from vibrating. I did this in 1994 and it's still
in place today. It did take a while to disassemble the kick panel to the
point that I could get the ICU out, but there appears to be no other way to
do this on a Honda.
You can also try disconnecting the seatbelt switch at the buckle, but the
cars I've tried this on are smart enough to sense this and permanently
illuminate the warning light, which is also annoying.
Hope this helps.
TeGGeR®
www.tegger.com/hondafaq/
TCS
Guest
Posts: n/a
On Thu, 17 Feb 2005 15:14:23 -0500, andrew416 <robinbuilders@netzero.com> wrote:
>buzzer??????
During that era I'd simply find the buzzer and unplug it.
Imminent Vengeance
Guest
Posts: n/a
> buzzer??????
Buckle up before starting the car.
Alex Rodriguez
Guest
Posts: n/a
In article <0a679dbae5d148696ec5fde10d6762c2@localhost.talkab outautos.com>,
robinbuilders@netzero.com says...
>buzzer??????
Buckling your seatbelt is usually the best way to shut it up.
Alex
andrew416
Guest
Posts: n/a
buzzer??????
Old May 20, 2008 | 10:16 PM
AllenB's Avatar
Holy Crap...this thread is why I didn't buy a Honda...too many prepubescent punks slinging mud back and forth about absolutely NOTHING. My wife on the other hand....likes her Fit and doesn't read Honda forums. I'm trying to find out how to disable the seat belt chime and I read a 5 page post and not ONE solution...just a bunch of people bitching about why you should wear a seat belt. Sheesh... Volkswagens don't have @#! up issues like this thank God. German engineering rules!
My .02 Flame suit engaged.
Old May 21, 2008 | 10:29 AM
99dx's Avatar
Your joking about German engineering right?!?!? Two of my friends have VW's. The first is a Jetta GLI and the dash caught fire because of a fan relay. Second problem he has was the turbo didn't cycle properly and he couldn't even get out of his driveway. Second friend has a Jetta TDI and his dash caught fire as well. His is an 03. You would think the "german engineers" would have figured this out. It's been an ongoing problem that they know about and didn't recall it until a few VW's burnt to the ground.
Every car has it's issues the VW's seem to have many. One of my sales guys won't even take his Passat our of the city for fear of not being able to get home. VW...LOL!
Old May 21, 2008 | 10:40 AM
Kelmar's Avatar
Frequent FitFreak Poster
Can someone lock this? Seriously guys, this thread is
3 years old!
The fit wasn't available in the states then....
