Greddy catch can installed.
Old Feb 26, 2007 | 11:58 AM
805FitSport's Avatar
had some time on my hands so i thought id jack some more parts off my dead STi. its ok she won't notice.
Old Feb 26, 2007 | 01:04 PM
Originally Posted by claymore
You may experience unexpected pressure build up in your crankcase with the hose set up like that. The PVC system is designed to have a vacuum assist in extracting pressure build up from inside the crankcase. The way your using the Catch can has eliminated the vacuum assist and the system may not cope without assistance at high engine speeds leaving your engine with an internal pressure build up.
how did i know you would catch that? i might hook another how to the intake, still debating. oh a BTW i am using the BKR7E's.... they seem to work fine.
Old Feb 26, 2007 | 03:43 PM
03DSM-RSX's Avatar
Frequent FitFreak Poster
i dont think he actually hooked it up to the actual PVC. more like an oil breather.
isnt the PCV on the left side of the motor?
Old Feb 26, 2007 | 04:09 PM
yep.... just a breather.
Old Feb 27, 2007 | 03:04 AM
vbo's Avatar
vbo
This way is for giving fresh air to motor (ventiling), and the air with oil vapor pass to PCV and is connected to Intake manifold for having a permanent vacuum.
On my ep3 :
http://www.membres.lycos.fr/vvbboo/i.../schemvent.JPG
http://www.membres.lycos.fr/vvbboo/i...T/P1010008.JPG
http://www.membres.lycos.fr/vvbboo/i...T/P1010011.JPG
http://www.membres.lycos.fr/vvbboo/i...T/P1010012.JPG
http://www.membres.lycos.fr/vvbboo/i...T/P1010014.JPG
But greddy catch can is not a catch can for me. It's a soda can. A catch can is this ! I change my geddy catch next time.
SMC All Products!
http://i21.photobucket.com/albums/b2...1/IMG_4173.jpg
http://i21.photobucket.com/albums/b2...1/IMG_4174.jpg
Old Mar 1, 2007 | 03:05 AM
03DSM-RSX's Avatar
yes, but under WOT, air exits the breather, and sometimes oil too.
Old Mar 1, 2007 | 12:14 PM
And where did you come up with that one?
UMMM... disconnect your hose and give it some gas, you will feel air pushing its way out
Old Mar 2, 2007 | 05:00 AM
vbo's Avatar
vbo
The best way is to go out of PCV valve, to exhaust. Exhaust make a permanent air movement and a vacuum on the added hose.
You don't have oil go out Valve cover wy you have a permanent vacuum.
If you whant, you can put a OIl Catch between PCV valve and exhaust.
Old Mar 3, 2007 | 07:53 PM
03DSM-RSX's Avatar
where? from cars that are on the dyno that run open breather, you clearly see blue smoke come out. (burning oil)
BMW ALPINA
Sep 3, 2018 10:19 PM
2007FitBLK
Sep 10, 2012 01:58 PM
YazzFlute
Sep 15, 2007 12:56 AM
Jimmy101
Sep 7, 2006 07:43 AM
TeGGeR®
Jun 14, 2005 08:02 PM
