ECU & "engine running" signal question
Old May 4, 2005 | 11:16 AM
TeGGer®
Guest
Posts: n/a
How does the ECU know the engine's running? Does it use an alternator
output signal, or does it use the RPM pickup in the distributor?
Also, what's the purpose of the Starter Signal as used by the EFI main
relay? Is it only to energize the fuel pump relay while the engine's
cranking?
TeGGeR®
www.tegger.com/hondafaq/
Mista Bone
Guest
Posts: n/a
Re: ECU & "engine running" signal question
Crank postion sensor in the distributor
yes
"TeGGer®" <tegger@istop.c0m> wrote in message
news:Xns95F469625643Cteggeratistop@207.14.113.17.. .
> cranking?
> TeGGeR®
TeGGer®
Guest
Posts: n/a
"Mista Bone" <mistab0ne@nospam.net> wrote in
news:xT7Nd.6825$XY5.978@fe2.columbus.rr.com:
So the if the RPMs are above a certain amount, the ECU considers that the
engine is running?
I ask because obviously the crank angle sensor would be registering
movement even during starter operation.
doctor J
Sep 12, 2014 07:09 AM
CrazyPete
Jul 19, 2005 11:26 PM
dbacker1
Jul 3, 2005 02:44 PM
Thorsten Ostermann
Jun 22, 2005 01:43 PM
ernests131@charter.net
May 4, 2005 11:16 AM
