Bolt spacing
Old Mar 10, 2007 | 06:56 PM
DrDiff's Avatar
Bolt spacing
What is the bolt spacing for the Honda Fit Sport?
Is it the 4 by 100 mm spacing that other Hondas have?
Old Mar 11, 2007 | 06:07 PM
dacalac's Avatar
Yes the Honda Fit has a 4x100 bolt pattern.
Old Mar 11, 2007 | 09:25 PM
gimme's Avatar
Master FitFreaker
yep. 4x100. if you are going with aftermarket wheels, be sure to buy lugnuts. OE lugs are not the standard acorn. they have a rounded surface which touches the wheel. you can use them, but intime they will wiggle loose
Old Mar 21, 2007 | 09:00 AM
jim@tirerack's Avatar
Former Vendor
You also have to know the center bore and the offset. Just knowing the bolt pattern is not the whole story.
Old Mar 21, 2007 | 11:11 AM
WhatFreshHell's Avatar
hey Jim,
Or anyone else.
Is there guide we could look at to know what the offset should be for a specific wheel?
Thanks
Old Mar 21, 2007 | 11:15 AM
Former Vendor
It depends on the width of the wheels but you should be right around 40 to 48 mm offset. Wheels are going to be anywhere from 6" wide to 7.5" wide.
If I can help let me know.
Old Mar 21, 2007 | 11:18 AM
gimme's Avatar
Master FitFreaker
I think the center bore is 56.1
will check further
Sono
Jun 9, 2017 11:01 AM
Peter Nguyen
Apr 18, 2017 12:41 PM
concorde
Apr 29, 2012 09:35 PM
djk949
Jan 7, 2009 08:32 PM
Buddah
Canada Fit Forums & Clubs
Apr 3, 2006 10:36 PM
