Measurements PLEASE!!!!!!!
Old Mar 27, 2007 | 11:11 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
Hey guys, I really need some help here please.. I am going to be replacing the stock Fujita filter that came with my intake with a K&N Intake.. I was woundering if anybody
1) Knew the size of the filter
2) Knew the K&N sized filter that could fit
3) Could MEASURE the Fujita for me so I can match it up with a filter from K&N's website located here K&N Universal Air Filter, Crankcase Vent Filter, Flame Arrestor, and Filter Wrap Search by Dimension
so please help a Fitty Brotha' out
Old Mar 27, 2007 | 11:36 PM
leonine's Avatar
most likely it is either 2.75 or 3 inches. Take the filter off and measure the distance from the insides of the filter to get your diameter. Then cross-check that with K&N. Also measure the length from top of filter to the bottom (before the rubber sleeve that fits over the pipe). You wil need that also.
Don't waste your money on a K&N filter. Heard plenty of stories about the filter oil getting into the engine and messing things up. Just pick up a generic one at your local auto parts store or order online.
Old Mar 27, 2007 | 11:58 PM
sLiVeRwOrM's Avatar
Well.. even if I get one from the store , i will need measurements.. I have no means to take it off and measure it.. hence me askin the community..
Old Mar 28, 2007 | 10:23 AM
leonine's Avatar
Maybe i am confused??? Do you have an aftermarket Fujita intake and you want to swap the filter out or are you using the stock airbox?
Old Mar 28, 2007 | 12:21 PM
sLiVeRwOrM's Avatar
Yeah, I have an aftermarket, and I just need the measurements so I can find something that will match it.
Old Mar 28, 2007 | 12:25 PM
leonine's Avatar
now i am really confused. Correct me if i am wrong but you have to take the filter off to replace it right? So if you take the filter off (using a screwdriver to loosen the clamp) then take the measurements with a ruler you should be good to go.
Old Mar 28, 2007 | 02:02 PM
sLiVeRwOrM's Avatar
Thats correct. Only, when I take it off.. I will be unable to drive to get a replacement.
Its fairly hard to get access to the underside of the Fit also, seeing as how I have no garage or jackstands or anything.
Old Mar 28, 2007 | 02:16 PM
leonine's Avatar
give em a call or send em an email
Fujita Competition Air Intake Systems
Old Mar 28, 2007 | 02:36 PM
sLiVeRwOrM's Avatar
Geez, gotta love smart asses .. they said 2.5 inches.
Radi
Nov 29, 2018 04:56 PM
Rellikant
Aug 29, 2017 12:38 PM
413FIT
17
Mar 23, 2013 09:18 AM
Red Diablo
Aug 4, 2009 04:42 PM
kancerr
Sep 9, 2008 03:56 PM
