what does everyone else think
Old Mar 28, 2007 | 01:36 AM
fithouston's Avatar
Question what does everyone else think
first off thanks for any help you fitfreaks can provide
Ok so i have looked and looked and really havent found a bolt on axle-back or cat-back system that i like mainly beacuse of the muffler itself
so i found a vibrant muffler that i like and its black. ( sweet! )
I wanted to see what everyone elses thoughts and opinions were.
this would mean cutting off my OEM muffler and welding the new one any pros or cons to doing this vice a full bolt-on. also not sure if this muffler will fit i dont know the dimensions of the OEM muffler
Vibrant Performance ::.
Old Mar 28, 2007 | 02:52 AM
Chikubi's Avatar
For me, it's not my taste, but that doesn't mean it's bad. I would imagine any respectable muffler shop could weld it up to make it fit. I also think if you do that, you're better off having them fabricate the tubing/mounting flange from scratch as the inlet on this thing is larger than the stock piping, ~62mm vs. OEM ~50mm.
Old Mar 28, 2007 | 03:14 AM
fithouston's Avatar
cool deal you answered a question that i needed (OEM-50mm)
also so no your taste was it the look or something else?
thanks
Old Mar 28, 2007 | 01:07 PM
iheartmyGD3's Avatar
thanks
To each his own. But honestly, I'd probably invest in an axle back instead and go with a brand that has a good rep. After that , I'd save more money to get a spoon B pipe since it will directly BOLT ON to any axle backs out there.
Old Mar 29, 2007 | 02:47 AM
Chikubi's Avatar
thanks
Glad to have helped some. Yeah, it's mainly the look. The black paint just seems kind cheap to me -- I can picture it flaking off really soon after you put it on from gravel, road debris, etc. and looking beat as a result. Also, since there's no brackets for hanging it, they're gonna have to be added, and that's going to ruin the finish as well (where they're welded on). Still, you gotta go with what you like, so you be the final judge. I know not everyone's into what I have either (J's Racing titanium), but I'm happy with it, so you're feelings in the end are all that matters.
Old Mar 29, 2007 | 02:57 AM
integradriv3r's Avatar
You should just have a welding shop custom fabricate a full cat back with the piping welded to the muffler. You could probably get it pretty cheap.
Old Mar 29, 2007 | 03:01 AM
Chikubi's Avatar
Agreed, it's usually better (and cheaper in the long run) to save and buy excellent parts from the get go.
As for the center-pipe, Spoon is good, but if you're going to go with this muffler, better to get a Skunk2 pipe as it's already 60mm. That way, you can keep the piping from the muffler 60mm as well, which is only 2mm smaller than the inlet on the muffler and a whole lot less restrictive than if you were going from 62>50mm like the Spoon and OEM piping.
Old Mar 29, 2007 | 03:47 PM
HFit USA's Avatar
Frequent FitFreak Poster
hey bro i still have my Aspec axle-back and cold-air if ur interested just hit me up....they are both in good conditions......let me know im willin to let go both for $200...i need to sell them
Old Mar 29, 2007 | 04:51 PM
fithouston's Avatar
hey hfit yeah can you pm a pic of the axel abck and which cold air do you have i order a weapon r sri so i'll have to see how that goes before getting another one
Old Mar 31, 2007 | 03:16 PM
dacalac's Avatar
this will (in my mind) always be the bar to which all others are compared to:
RS*R Exmag
Best low profile exhaust made. Other than OEM. :P
Old Mar 31, 2007 | 10:05 PM
sirhc's Avatar
Senior Member
i second dat,especially wen ur a little tight on da budget but still nice to have the axle backs...jus need to save up for da best one
Old Apr 1, 2007 | 03:06 PM
moondog's Avatar
So the Spoon B-pipe is the same diameter as the stock pipe? I've got a Tanabe Concept G axle back and want to add a aftermarket mid pipe. I was leaning towards the Spoon but now I'm not sure it's worth the $ ($350) if it's the same size as stock. Does anyone have a Skunk2 or Megan with a Tanabe muffler?
Old Apr 1, 2007 | 08:59 PM
fithouston's Avatar
thanx for all your help guys but i gave in and bought a a-spec axel-back with the burnt tip thanx hfit
Old Apr 1, 2007 | 09:02 PM
HFit USA's Avatar
hey no prob. bro always a pleasure to help out fellow texans...haha...anyways hope to see pics of it and being used once again..
Old Apr 1, 2007 | 09:32 PM
fithouston's Avatar
well i tried with hand tools to break my oem bolts and they wouldn't budge so I'm gonna have to take it to a shop. i cant get a good grip to loosen the nuts
Old Apr 4, 2007 | 12:29 PM
milano sol's Avatar
no Spoon B-Pipe IS slightly larger diameter piping compared to OEM. if you need exact specs on both i can look for them (i forgot haha) but it is definetly not the same as stock.
as for the Skunk2.....if you read there site its not an OEM style b pipe since the flanges are different i think. you cannot by there exhaust as an axle back either. if you want skunk2 b pipe you NEED to run skunk2 exhaust as well and vice versa (according to thier web site). where as the Spoon b pipe is a direct OEM fit and will bolt up to ANY axle back (except Skunk2 that i know of) including the OEM exhaust.
if you like the flat black look check if the Apex'i NOiR is made as an axle back for the fit......
ryanroland
California - Bay Area Community
Jul 11, 2011 10:46 AM
Vaskar
Jul 30, 2010 10:23 PM
Luichenwai
Mid-Atlantic Community
Sep 26, 2008 01:14 PM
metsone
Sep 17, 2007 12:12 PM
blackgd3
Jul 23, 2007 03:01 PM
