New intake making me run rich?
Old Apr 16, 2007 | 01:09 AM
Ragnarok0mega's Avatar
Hey everyone, my and a friend custom made an intake last night, im pretty happy with it. Only problem is today, i was revving the engine a little bit checking to see if anything was coming loose, and i went to the back for some reason and saw it kicking back whaty i BELIEVE is gas....so im assuming im running rich (correct me if im wrong) is there any way to correct this?
Old Apr 16, 2007 | 01:28 AM
xdimsumx's Avatar
u sure it wasn't just condensation coming out of the exhaust? was it a little cold that day?
Old Apr 16, 2007 | 01:56 AM
George02's Avatar
def not rich. that's usually normal. that's how they come from the factory. the intake if anything would make u run lean
Old Apr 16, 2007 | 09:23 AM
tlohman81's Avatar
I agree. More than likely, it's just condensation. You're intake, in theory, will be ingesting more, or denser, air into the engine which, in extreme cases, will cause you to run lean. If you are running so rich that fuel is coming out of your exhaust, you have a lot bigger things to look at than your intake
Old Apr 16, 2007 | 11:49 AM
manxman's Avatar
NOT POSSIBLE for raw gasoline to be coming out of your exhaust, unless you have removed your catalytic converter and the engine is missing on at least one cylinder. If you were "running rich", the symptom would be BLACK smoke out the exhaust.
Old Apr 16, 2007 | 07:45 PM
haha alright thanks guys, that plus the MPG loss just made me wonder...though to loss may be just from me flooring it just cuz i like the little bit more push it gives me and the sound =)
ansi
Feb 15, 2017 07:27 PM
fit4afit
Feb 16, 2010 03:31 AM
iLUVYOURGE8
Jun 20, 2009 01:47 PM
romanc333
Jun 5, 2008 02:07 PM
dale.spencer@cox.net
Oct 12, 2005 12:30 AM
