Carburetor options/retrofit '87 Honda Accord
Old May 4, 2005 | 11:16 AM
edmacatack
Guest
Posts: n/a
Hi: I just bought an '87 Accord, and I found out it needs a new carb.
The carb replacement is very expensive. It is listed as a Holly Carb.
Does anyone know of any other carburetors I could use in place of the
factory issued part, that will more than likely cost me a lot less than
the Holly?
Thanks
charl_z@yahoo.com
Guest
Posts: n/a
Re: Carburetor options/retrofit '87 Honda Accord
find one from a junk yard
Daniel J. Stern
Guest
Posts: n/a
Yep. The final generation of Asian carburetors, in the 1980s, tends to
wear out in ways that cannot be fixed or undone with a rebuild, and
replacement becomes the only workable option. The ones listed as
"remanufactured" are usually virtually all new parts, hence the near-$600
pricetag. Junkyard carbs are usually just as bad (or worse) as your own.
No, it is not a Holley. It's a Keihin.
> factory issued part
There is no direct-fit replacement other than a correct factory-type unit.
Depending where you live, your emission laws may or may not forbid you
from using anything BUT a factory-type unit.
DS
andrew416
May 21, 2008 06:52 PM
sade001
Oct 15, 2005 09:40 PM
Dick
Jul 21, 2005 07:31 PM
PMS
May 4, 2005 11:16 AM
Zelk
