'78 Honda Civic - Stuck wheel drum .....
Old May 4, 2005 | 11:16 AM
Alexis Ostapenko
Guest
Posts: n/a
Hi, All Responders:
THANK YOU ALL FOR YOUR REPLIES!
I've learned so much from you.
Herewith are the results.
(My original request is at the bottom for reference.)
1) Stuck rear wheel drum.
After I backed the shoes off to the maximum, the drum
just slid off the axle. (The linings were still OK to pass
the inspection.) The linings had eaten into the drum, and
a ridge formed at the outer edge. There was also quite a
bit of encrusted rust. This ridge was preventing the drum
to come off. I filed the ridge off, and now everything is
honky-dory.
2) Mayonaise-like sludge on the oil filler cap.
Most likely, this is the result of condensation water
since lately I have been driving mainly 5-6 mile commuter
trips. Later, I'll make the "lick test" to verify that
the sludge does not result from a coolant leakage.
(Coolant makes it taste sweet. This was suggested by one
of you.)
Thanks again to all of you. Alex
CC: My original message:
Please help!
What to do? I cannot get off the rear wheel drum
on my trusty '78 Honda Civic (just 100,305 M on it)
to check the brake shoes. The nut is off, and I've
loosened the brake adjustment, but the drum does
not come off. (It can be rotated.) I've tried
prying with a screw driver between the drum edge
and the back plate, but no luck.
The other rear wheel drum just slides off.
The other question I have is about the oil filler cap.
Especially when it is cold outside, the oil filler cap
is covered with some Mayonaise-like substance.
What is this emulsion? Does it do any harm?
I would appreciate any suggestions. Especially,
about the drum.
Thanks, Alex
Gordon McGrew
Guest
Posts: n/a
Re: '78 Honda Civic - Stuck wheel drum .....
On Tue, 22 Feb 2005 17:51:26 -0500, Alexis Ostapenko <ao03@lehigh.edu>
> of you.)
Feels good to fix it yourself, doesn't it?
I would skip the lick test (yucch.) If the coolant level isn't
dropping it's OK. The six mile trips are a problem though. Having
that much condensation in the crankcase is bad. You should change the
oil now and then start taking it on a 20+ mile ride at least once a
week. Even then, you should change the oil every three months
regardless of milage.
TeGGer®
Guest
Posts: n/a
Alexis Ostapenko <ao03@lehigh.edu> wrote in
news:421BB76E.1090104@lehigh.edu:
> Hi, All Responders:
> honky-dory.
And I got laughed at for suggesting just this.
>:^P to all the laughers.
> of you.)
Take it for a minimum half-hour highway drive FIRST, then see if the
mayonnaise is still there. If it is, THEN taste it. But wipe it off the tip
of your tongue after.
TeGGeR®
www.tegger.com/hondafaq/
TeGGer®
Guest
Posts: n/a
gRmEcMgOrVeEw@mindspring.com (Gordon McGrew) wrote in
news:4nfn115jt4fg17dbod4edj894510mfi398@4ax.com:
Every TWO months in winter if mayonnaise is forming. Your bearings won't
appreciate the water in the oil.
TeGGeR®
fenixfire077
Jul 15, 2012 12:37 AM
jadr09fit
13
Jul 1, 2011 11:17 PM
danielle1432
Oct 10, 2005 12:36 PM
r2000swler@hotmail.com
Sep 25, 2005 11:30 AM
Alexis Ostapenko
May 4, 2005 11:16 AM
