Crankshaft Pulley Bolt on 1989 Accord SE-i: My story
Old May 4, 2005 | 11:16 AM
justinreigle (at) gmail (dot) com
Guest
Posts: n/a
Hello all,
I'll try to keep this short and sweet. Last week I decided to spend
my President's day long weekend disassembing my car to replace the
timing belt. It has 180k on it and this is the 3rd belt change. Both
of the previous were done by independent shops who apparently use a
600lb impact or so to tighten the crank pulley bolt.
With the car jacked up and pretty well opened up, it was time to
remove the crank pulley bolt. Of course, it was near impossible. I went
at it for a good 20 minutes with a 240lb air impact. I even tried the
rocking technique (fwd and rev.) to no avail.
My engine does not have the hex groove in the pulley, so I can't use
the special pulley holder tool, so I decided to craft my own. I took
a trip to the hardware store and got a 4 foot length (more than needed)
of aircraft cable (that's what it was called...). It is essentially
about
5/16th inch thick strand of steel cable which cost about 4 bucks. In
addition to that, I also purchased a rope/chain clamp for 50 cents. You
can find it in the rope/cable section at probably any hardware shop.
I'm sure it has a simple name, but I do not know it. So I will attempt
a little ascii art to describe it:
_____
/ \ <- small u-bolt
-|---\ /---|- <- Bracket that moves towards the inside of U-bolt when
-|---|-|---|- adjusted. Note the groove in the middle that is made
| | to hold the rope in the center of the bracket as it
=== === clamps the u-bolt.
=== === <- Nut on either side of U-bolt for moving metal bracket
| | inward which tightens the hold on the rope/cable.
Sorry for the crappy drawing, if someone wants I can take a picture of
the rig this
evening and post it to my website.
Anyway, here's how I used the cable and cable clamp to hold the pulley
still:
1) align the crankshaft pulley such that one of the two holes in the
pulley is on the top and it's essentially parallel with the
engine's axis
2) thread your cable through the top hole on the crank pulley and
pull it around the left engine mount so the portion of the cable
that's in the crank pulley hole is the halfway point in the
cable.
3) position the cable as low on the mount as it will go
(engine side of mount, since it's lower than the chassis
side of the mount) and put the ends in the cable fastener/
u-bolt thingy, pulling the fastener as close to the mount as
possible to eliminate slack in the cable.
4) tighten the hell out of the cable fastener until you can
tighten no more and give it a good hard tug to make sure its
secure. this must be secure. I selected the smallest one my
cable would fit through to ensure I could get it good and tight.
5) I put a floor-jack & board under the oil pan and jacked it once
or so to take some stress off of the left engine mount since
I'm sure this could kill it if it's old and brittle.
6) pulley should be stationary.
At this point, grab the breaker bar (24in +) and a 19mm impact grade
socket and impact grade extension and go to town. Mine losened up with
two loud pops. The first just broke it free the second made it easily
to turn with a normal socket. Bouncing on it seems to help. I used the
same technique to tighten it too.
Some things to note:
I had all drive belts removed. If they weren't, then they would've
gotten in the way of the contraption.
I did this from under the front left corner of the front bumper with
the car on jackstands.
I noticed that the pulley cut through two strands of the cable.
The cable also stretched about 1/8th inch which required me to
reposition my breaker bar for better leverage. I think it had a long
way to go before the cable tore through competely, but just something
to watch out for.
Hope that the cable fastener doesn't slip and position your body for
a worst case scenario (e.g. breaker bar snaps).
So there it is. Less than five dollars to construct a decent pulley
holding contraption.
If my pulley didn't have holes in it, I'd be screwed :)
Hope this helps someone.
- Justin
chip
Guest
Posts: n/a
Re: Crankshaft Pulley Bolt on 1989 Accord SE-i: My story
On 25 Feb 2005 13:51:24 -0800, "justinreigle (at) gmail (dot) com"
<justinreigle@gmail.com> wrote:
>Hello all,
>about
> _____
> / \ <- small u-bolt
>the rig this
>still:
> engine's axis
> cable.
>to watch out for.
>- Justin
the pulley had holes in it though. so you just didn't have the proper
tool, that car used a very different pulley holder, not the giant hex
one.
Chip
jim beam
Guest
Posts: n/a
justinreigle (at) gmail (dot) com wrote:
> Hello all,
> about
> _____
> / \ <- small u-bolt
> the rig this
> still:
> engine's axis
> cable.
> to watch out for.
> - Justin
that's a good job justin, and i'm all for improvisation if you're stuck
in the backwoods somewhere with the "deliverance" banjo's twanging
uncomfortably close by, but, as a hopeless pedant, may i ask whether it
was worth the time, effort & damage risk compared to buying the $85
tool? guaranteed not to [expensively] damage your vehicle.
Gerry
Guest
Posts: n/a
> > Hello all,
Both
went
the
use
took
needed)
> > about
In
You
shop.
attempt
> > _____
> > / \ <- small u-bolt
when
made
it
bracket
of
> > the rig this
pulley
> > still:
the
> > engine's axis
> > cable.
grade
with
easily
the
with
long
something
> > to watch out for.
for
> > - Justin
stuck
it
Could you supply a link which shows the tool on the internet. I have
the factory manual for a 19992 Civic and there aren't any pulley
holder shown. My civic also has the holes around the pully.
jim beam
Guest
Posts: n/a
Gerry wrote:
<snip>
http://www.etoolcart.com/index.asp?P...OD&ProdID=5098
needs the handle as well.
Guest
Posts: n/a
The damage risk is a good point Jim. Believe me, as I sheared off my
3rd Craftsman socket, I worried about damage to my car.
Let me disclose that as I preform work on my car, I learn as I go. I've
done a few major things so far and will continue to do more (the car
needs it). I think the amount of time I spend on a task reflects my
learning curve and instinct to go slowly to learn.
It took me about 10 working hours to do the t-belt, and if I did it
again, I bet I could do it in four. So, I go into these projects with
plenty of time on my hands. I'd have to say the time aspect was a
non-issue.
Regarding the damage for the 85 dollar tool, I wish I owned the tool.
In fact, I have the factory manual and nowhere does it mention there is
a tool for this car. There's also a civic 2004 in the family, which we
have the shop book for, that clearly mentions a special tool which I've
acquired for when the belt comes due. But let's worst case scenario:
my crank pulley cracks and I'm out 45 bucks to the local salvage yard.
I would definitely waste a few hours, but all in all, I'd still be
ahead in cost. (Anything worse than the crank pulley and I'd be screwed
As far as time wasted vs. money saved, when I'm working on the car, I'm
quite happy and am honestly looking to spend as much time listening to
the radio and wrenching as possible (don't tell the wife ;).
I think my improvisation was a good little device and will post a link
to some pics within the hour. I'm sure my risk of damage was worse than
using the proper tool, but, hell, I enjoyed the challenge :)
- Justin
Guest
Posts: n/a
Hey guys,
As mentioned here are the links:
http://reigle.org/rig1.jpg
http://reigle.org/rig2.jpg
http://reigle.org/rig3.jpg
http://reigle.org/rig4.jpg
Hopefully my site will be up years from now when someone is
searching for this particular model Honda :).
Enjoy
- Justin
SoCalMike
Guest
Posts: n/a
aw, cmon, man... ida never thought of that. and if anything were to get
ruined, itd be the cable. i say "way ta go, justin!"
TomP
Guest
Posts: n/a
Pretty inventive Justin. A fellow could do all that...
Or.
Drive over to the local garage and have the bolt broken loose. Bolt
threads lubed and then gently retorqued. You could then safely drive back
home and do the job without all the fuss.
Just a thought, as this worked well for me when I did the Wife's Integra.
"justinreigle (at) gmail (dot) com" wrote:
> Hello all,
> about
> _____
> / \ <- small u-bolt
> the rig this
> still:
> engine's axis
> cable.
> to watch out for.
> - Justin
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
Guest
Posts: n/a
I called two shops that are within 2 miles and both refused to do that
for insurance reasons. One of them even laughed at me, heh... The car
was also 4 hours disassembled, so all of my around-towning happened in
a different car. By the time I had it apart I was assuming my air
impact would spin it right off. Oh well, that definitely would've been
easier though... Maybe I should've offered them 10 bucks?
TomP
Guest
Posts: n/a
Way back when I worked in a repair shop, we did all sorts of short work,
like that, for a simple six-pack of beer or soda. Or, a small cash
donation to the "slush fund." No paper, you were never there...
Insurance reasons? What's up with that?
Tp,
-------- __o
gmccx
Guest
Posts: n/a
Too many lawyers running the world. If that thing came loose or fell
off while driving back, and especially if any sort of accident happened,
lawyers would line up to handle the resulting lawsuit.
> Tp,
> -------- __o
George
http://people.delphiforums.com/gmcc
Alex Rodriguez
Guest
Posts: n/a
In article <1109368284.204220.29980@l41g2000cwc.googlegroups. com>,
justinreigle@gmail.com says...
>Hello all,
I recently did a 2.5 Acura and tried a 650FT/LB impact wrench and that
didn't help at all. I wonder just how big and impact wrench you really
need to loosen the nuts?
Samething with the 2.5. Unfortunately I didn't do the right thing until
after I had broken the pulley. :(
>--* some good advice snipped *----<
I ended up doing something similar. I wrapped the old belts around the pulley
and then wrapped some nylon sraps around the pulley. I then tied the ends
and then wrapped that around a breaker bar. I put a 2X4 across the engine bay
and then slipped a chaeter bar over the breaker bar and propped it against the
2X4. I then took my other breaker bar with attached cheater and used it to
break the nut free. It took two of use to do it, but it worked. It is really
stupid that Honda could not come up with a better way to do this.
Alex
Alex Rodriguez
Guest
Posts: n/a
In article <1109386824.741c111e280f3fb1f5101bddfe95616a@teran ews>,
nospam@example.net says...
When I was doing a 2.5 TL, I had no choice. I could not find any place
that had the tool. The local acura dealers all refused to order the tool
for me. For me it was definitely worth it.
Alex
Alex Rodriguez
Guest
Posts: n/a
In article <1109394394.606454.244310@l41g2000cwc.googlegroups .com>,
If you broke the pulley trying to get it out of your car, why do you think you
could get it out of a car at the junkyard without also breaking it? Just
curious. This was something I had to think about when I was in the same
situation. I did break the pulley and ended up buying a new one.
Alex
jim beam
Guest
Posts: n/a
>>Hello all,
i was starting to think like this as i started the job with my usual
1/2" tool set. but i have to say, with the 3/4" driver/extension bar,
and the proper pulley holder, that bolt comes right off no problem.
maybe i loosened it with the 1/2" set, but don't think so.
regarding air tools, it's comparatively rare for domestic compressors to
be able to supply sufficient cfm at sustained pressure for the tool to
work as rated. once the pressure [quickly] drops, so does the torque.
the perfect excuse to buy that really /big/ compressor you always wanted!
> Alex
Giovanny Alan Alvarado
Apr 27, 2025 01:09 AM
99ls1tj
Sep 21, 2018 10:00 PM
Ailur
Oct 27, 2016 06:48 AM
jim beam
May 4, 2005 11:16 AM
jjeansonne
