Can you pushstart MT 1991 Civic?
Old May 4, 2005 | 11:16 AM
r2000swler@hotmail.com
Guest
Posts: n/a
I only ask because looking at the ECM PRG-EFI relay it
sure looks like it would be rather difficult to do.
Anone done it?
Just thinking about the time my starter died in my
1981 Subaru 4WD. I was parked on a hill, so it was easy
to slip it into reverse, roll backwards and pop the clutch.
I suspect you would have to get a Civic up to speed, pop
the clutch and turn the ignition switch all at about the
same time.
I may have posted this smae header with no text, blame
Google Beta.
Terry
Chopface
Guest
Posts: n/a
Re: Can you pushstart MT 1991 Civic?
> Anone done it?
> same time.
> Google Beta.
> Terry
I've done it a few times after leaving my lights on and draining the
battery. Just have they key in the normal running position and 'pop' the
clutch. The 'pop' can be fairly gentle, you don't have to totally 'dump'
it.
The owner's manual tells you not to do this though. My guess is that it
may be a little hard on the cat. because some raw fuel might go through
the engine unburned. I'm sure someone will explain for sure why its not
the best for your car.
Mark
ycleptor2@cs.com
Guest
Posts: n/a
I've push-started a 90 prelude 2.0 Si with no problem.
And many times an 84 Jetta GLi.
Cheers,
Mike Davis
Randolph
Guest
Posts: n/a
> Anone done it?
> same time.
> Google Beta.
> Terry
You need to have the ignition in "RUN", just like when push-starting any
other car. No need to put the ignition in "Start". As you release the
clutch, the engine will start turning (firing or not) and the sensors in
the distributor will tell the ECU that the engine is turning. The ECU
will then turn the fuel pump back on. There is usually enough residual
pressure in the fuel system to get the car started before the fuel pump
starts running.
If the battery voltage is 0, you probably will not be able to push start
the car. Alternators need battery voltage to start delivering power.
Older DC generators could pull themselves up by the boot straps.
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
motsco_ _
Guest
Posts: n/a
> Anone done it?
> same time.
> Google Beta.
> Terry
If there's enough juice to make the interior light glow (even a tiny
bit) just put it in second, turn on the key (fuel pump will hopefully be
able to pressurize the rail), let it roll to walking speed, then let the
clutch out sharply, then immediately back in. You only want to turn it
over, and if you leave the clutch out, it can't start very well. With
this method, I drove an old Volvo all summer without a starter. I could
start it in the length of two empty curbside parking spots (had to):-)
P.S. I was a teenager, and tried to always have somebody along for the ride.
'Curly'
Mista Bone
Guest
Posts: n/a
if PGM-FI (main relay) is dead, no push starting is gonna help!!!!!!!!!!
But if you ever need to bump start, use 2nd gear!!!!!!!!!!
Even on level ground, I was able to bump start my 93 Civic. My case was too
big of a stereo 8-9 years ago.
<r2000swler@hotmail.com> wrote in message
news:1110570950.569696.240190@z14g2000cwz.googlegr oups.com...
> Anone done it?
> same time.
> Google Beta.
> Terry
Abeness
Guest
Posts: n/a
TeGGer® wrote:
> No, you can turn the ignition on first, then do the push thing. As Mista
> Bone says, use 2nd gear.
Why 2nd? I assume it has to do with gear ratios or something, but it
would be nice to know something a tad more specific.
Also, would reverse work all right, if, say, one were stuck facing
forward on an uphill (as I am on my block)?
Abe
SoCalMike
Guest
Posts: n/a
Abeness wrote:
>> Mista Bone says, use 2nd gear.
2nd is the general "crawling" gear. 1st would likely be doable, but if
it doesnt catch, itll lurch a lot! 2nd is more matched to the speed
youll be pushing the car.
sure. ive popped the clutch on my 98 in reverse, and it started. lurched
a bit, tho. likely a lower gear ratio than 1st.
> Abe
Abeness
Guest
Posts: n/a
Thanks, guys.
Gordon McGrew
Guest
Posts: n/a
On 16 Mar 2005 00:03:04 GMT, "TeGGer®" <tegger@istop.c0m> wrote:
>Abeness <news@nada.x> wrote in news:W_adnb3-bK0TuarfRVn-tA@rcn.net:
>The gearing makes it easier for the wheels to turn the engine.
Also, if someone is pushing, it prevents them from denting your trunk
lid with their head.
>First or reverse will work too.
Abeness
Guest
Posts: n/a
LOL!
breadman
18
May 15, 2014 06:32 AM
06Jazz
Sep 3, 2011 10:08 AM
HondaCrazy
Oct 18, 2005 09:32 PM
Pailyn
Jul 3, 2005 04:05 PM
Sk8rgrrl22
May 4, 2005 11:16 AM
