What are the exact tools needed to install a exhaust system
Old Jun 18, 2007 | 03:14 AM
wobuffet's Avatar
installing a greddy ti-c axelback soon
i just want to know the exact tools needed to install the exhaust system on the honda fit
if anyone knows all the exact tools please let me know so i can have them ready
thanks alot
Old Jun 18, 2007 | 09:00 AM
phil_qc's Avatar
A ratchet kit... 12mm if I remember corectly.
If you want, you can jack your Fit by the rear tow
hook and put 2 jack stand at both rear (right/left)
jack location but I did it without lifting the car...
You could also remove the right rear wheel for better
access but it's not necessery (spel???)
You may need a new exhaust bushing/gasket (the donut
between the pipe and the axleback) but if your car
is new, it should be easy to remove, if not, it's a
$5 thing that you can buy at auto parts or Honda dealer...
Philippe
Old Jun 18, 2007 | 01:32 PM
wobuffet's Avatar
thanks man
Old Jun 18, 2007 | 02:24 PM
manxman's Avatar
You SHOULD use a new crush gasket whenever you R&R the muffler. They distort with each R&R and then leak. Another helpful tool is a large slip-joint pliers like "ChannelLock"'. This tool makes it easy to pull the rubber doughnut hangers over the hooks to hang the muffler. A little silicone grease also eases getting the hanger doughnuts over the hooks on the muffler and the underbody.
Old Jun 18, 2007 | 02:25 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I took my muffler off without any jacks. Got on the ground with my ratchet.
Also, some sort of penetrating spray/lube. The rubber hangers arent much fun.
BLAH, I got beat to it. The donut will be fine. Just use the old one. Its not like the Fit is a 15yr old car.
kurrupt
Mar 22, 2017 07:04 AM
FIT_maniack
Jan 18, 2011 04:17 PM
mugenfit79
Mar 29, 2008 10:19 PM
ericman20
Mar 29, 2008 08:09 AM
agent_paul
Feb 2, 2008 06:45 AM
