Vibration when in Reverse
Old May 4, 2005 | 11:16 AM
garcia
Guest
Posts: n/a
I have recently noticed that when I put my car in reverse their is some
vibration, it is the only time that the car vibrates. Does anyone know
what it might be?
motsco_ _
Guest
Posts: n/a
Re: Vibration when in Reverse
> what it might be?
It doesn't matter at all, unless your car is a Honda.
If it's a Honda, tell us the model and year, the mileage, what kind of
tranny it has, how long you've owned the car, and when you last changed
the tranny fluid.
'Curly'
garcia
Guest
Posts: n/a
I have a 93 Honda Accord Ex. I am the 2nd owner, It has 145,000 miles on
it. My uncle said that he never did have a transmission flush but that he
changed the fluid at about 100,000 miles. It is a 4 cylinder 2.2 liter.The
vibration started a just over a week ago. This past Saturday I decided to
change my engine oil, filter, wireset, distributor cap and rotor. It drove
fine for a day and today on my way home from work I noticed that when I was
driving or came to a stop the car was not running right at stop lights the
RPMs go below the one and when I turn on the headlights they get dim. I
guess I'm having many problems and it would be great if I could get some
help problem solving.
jim beam
Guest
Posts: n/a
> what it might be?
broken motor mount causing driveshaft alignment problems. that's what
it was for me.
Dee
Guest
Posts: n/a
<< or came to a stop the car was not running right at stop lights the RPMs
go below the one and when I turn on the headlights they get dim >>
Did you make any adjustments to the alternator belt when you worked on it?
My lights were dimming like yours and the a/c fan motor was slowing down in
traffic. It was a loose alternator belt.
motsco_ _
Guest
Posts: n/a
If you washed it under the hood (?) you may just have some moisture
under the cap. Examine inside the cap, and look carefully for red 'dust'
inside the distributor. If you do, do a google search, or search this
group for red dust honda distributor. Or look in the FAQ, mentioned above.
You can change your own tranny fluid, just replace exactly, and use only
Honda Z1. Warm up tranny, Let it drain for ten minutes. Wipe off and
reinstall magnetic plug. Refill. Drive a few days, do it again. Check
the records to see if the valves have been adjusted too.
'Curly'
Shredded_Wheat
Oct 26, 2013 11:50 AM
chefkojak
Oct 1, 2005 09:33 PM
rshingrani@gmail.com
Jun 18, 2005 10:17 AM
braxmed
May 4, 2005 11:16 AM
Cherokee
