'91 Accord Radio Power Question
Guest
Posts: n/a
The radio in our '91 Accord would quit working frequently, the display
fading in and out, so I decided to replace the unit with a Panasonic CD
player. No problem, until I tried to locate the battery power lead that
provides 12V power all the time. This lead and all radio wiring leads are
clearly identified on the old Honda radio. Problem is, the continous power
lead is dead. And the Panasonic radio needs that lead to work, along with
power from the 12V Accessory lead. I provided 12 volt power from a terminal
in the fuse box, via a wire, and the Panasonic unit worked. Without this
power, it is dead, even with power from the Accessory position. Question
is, anyone know anything about the 12V battery lead to the radio dying, and
why? All fuses look good. Secondly, where is a good source to get
continous 12V battery power, even with the key out of the ignition?
Thank you,
- Phil
Thank you,
- Phil
Guest
Posts: n/a
Re: '91 Accord Radio Power Question
> Thank you,
> - Phil
The fuse that's blown may be under the hood, called 'Back-up' (radio)
'Curly'
> Thank you,
> - Phil
'Curly'
Guest
Posts: n/a
Thank you. That was exactly the problem!
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:424252F2.5030000@interbaun.com...
>> are clearly identified on the old Honda radio. Problem is, the continous
>> power lead is dead. And the Panasonic radio needs that lead to work,
>> along with power from the 12V Accessory lead. I provided 12 volt power
>> from a terminal in the fuse box, via a wire, and the Panasonic unit
>> worked. Without this power, it is dead, even with power from the
>> Accessory position. Question is, anyone know anything about the 12V
>> battery lead to the radio dying, and why? All fuses look good.
>> Secondly, where is a good source to get continous 12V battery power, even
>> Thank you,
>> - Phil
> 'Curly'
>> Thank you,
>> - Phil
> 'Curly'
Guest
Posts: n/a
<snip>
<snip>
It is not a good idea to use the factory constant power wire for after
market stereos. With the factory stereo, the constant power wire is used
only for backup of the FM presets etc., it is not used to power the
stereo. Power to the stereo comes through the ignition switched wire.
On the after market stereo, power is taken from the constant on wire,
the ignition switched wire is used only to sense if ignition is on or
off. The constant on wire you used is fused with a 7.5A fuse and is
shared with the clock and the memory backup for the ECU. If you crank up
the volume a bit, you can easily exceed the 7.5A fuse rating.
It is better to pull a new wire from the under-dash fuse-box. It has
options connectors just for this purpose. Options connector "D" in your
Accord is always on, fused with a 50 Amp fuse located in the under-hood
fuse box. You will need to supply your own 10 Amp (or whatever is
recommended in the manual for the new stereo) fuse in line with the wire
to the stereo.
Guest
Posts: n/a
Thank you for the informative answer. I may do as you suggested, but right
now, am wrestling with just trying to get the thing physically mounted!
What a pain! Impossible to gain access to fasten the rear of the unit to
anything under dash.
- Phil
"Randolph" <trash@junkmail.com> wrote in message
news:42427954.E85BF897@junkmail.com...
> <snip>
>> >> even
> <snip>
> to the stereo.
- Phil
> <snip>
>> >> even
> <snip>
> to the stereo.
damooster
Mar 1, 2010 03:35 PM
