shift boots
Old Jul 4, 2007 | 02:56 AM
its.ryu's Avatar
shift boots
im looking to replace the stock shift boot i have for a leather one. i couldnt find anything on it. would a shift boot from integra t-r or civic t-r fit in the fit? i know that the mugen shift boot because aj racing has it in their fit. looking to get a skunk2 or blox shift knob with it. im new to this so any help would be great.
eBay Motors: JDM Genuine Honda Integra type R DC2 Shift boot NEW Red (item 120138489142 end time Jul-06-07 09:59:35 PDT)
or
eBay Motors: JDM Honda Civic type R EK9 Shift boot NEW red (item 120138489156 end time Jul-06-07 09:59:38 PDT)
Old Jul 4, 2007 | 11:59 AM
JDMchris.com's Avatar
I run THIS
I have the Type R in mine, but it takes some modification to fit.
Old Jul 4, 2007 | 12:58 PM
its.ryu's Avatar
what kind of modding would need to be done?
Old Jul 4, 2007 | 01:29 PM
I run THIS
boot needs to be cut practically in 1/2 and then depending on how you want to mount it then theres a few things you can do.
Old Jul 4, 2007 | 01:34 PM
fit4kris's Avatar
Go for the Mugen!
Old Jul 4, 2007 | 01:54 PM
its.ryu's Avatar
but it costs more tho =(
Old Jul 4, 2007 | 02:09 PM
I run THIS
you can also do the 06-07 Si shiftboot, which would be easier or RSX boot.
Old Jul 4, 2007 | 02:11 PM
its.ryu's Avatar
ill look in to that. thanks Chris
Old Aug 1, 2007 | 12:06 PM
aznguyen316's Avatar
would you happen to have pics so I can see how the boot looks.
I assume you use the stock ring? I haven't seen under the shifter so I'm unsure how the boot would mount. I'm guessing similar to my integra with a frame that boot wraps around at the bottom?
Old Aug 1, 2007 | 12:19 PM
I run THIS
there was someone that did a DIY here, but its actually pretty easy. The Fit has less "tabs" on the bottom than the rsx or Si boot, however if you use most of them it should be ok. Theres 3 screws underneath as well (not for the boot) but I used those to hold it in place since I used a DC2 boot with no tabs on the bottom.
Old Sep 1, 2007 | 03:34 PM
thanks I'll look into it.
413FitMurtz
Jan 30, 2016 11:35 AM
JUSTinSANE671
Jul 10, 2011 04:03 AM
0r30kid
Feb 27, 2010 12:44 AM
RubyQQ1211
Feb 22, 2010 10:25 AM
ericman20
Jul 9, 2008 09:53 PM
