figuring MPG: proper procedures?
Old Jul 17, 2007 | 10:51 AM
Etrsi_645's Avatar
Question figuring MPG: proper procedures?
Ok, so I start with a full tank. If I want to measure the mpg over several tanks, do I need to fill every tank all the way OR only the starting and last one?
Are there any links to describing best practices on this subject?
thanks,
Old Jul 17, 2007 | 10:58 AM
xorbe's Avatar
Per tank, there is room for several % error. Average over
several tanks will be more accurate.
Use the same pump, stop at first click, to try to have a bit
more accurate per-tank numbers.
Old Jul 17, 2007 | 11:29 AM
spreadhead's Avatar
Miles traveled since last fill up = MPG
Gallons required to refill
Old Jul 17, 2007 | 12:36 PM
RedAndy's Avatar
MPG = miles driven / gas used.
1) Fill car up. Just fill up till the pump shuts itself off.
2) Reset tripmeter to 0.
3) Drive car till gas is pretty low, say till the low fuel warning light comes on.
4) Fill car up again. While filling, check your trip meter and divide the miles you drove by the gallons put in when you refill - that's your MPG for the last tank. Set the tipmeter back to 0.
5) Repeat for 10 or so tanks and you'll have a pretty good feel for your mpgs.
ps - It's best to run the gas pretty low to get a more accurate reading of what you put in when you fill up. Some gas pumps will shut off a bit sooner than others. If the tank is low when you fill up, this difference is minimized.
Old Jul 19, 2007 | 05:27 PM
AppleMac*Fit's Avatar
I never thought of that... but that makes perfect sense.
Old Jul 24, 2007 | 08:59 PM
Gordio's Avatar
However, if you take an average of many tanks, this error will disappear. For one tank/measurement, that'll make it more accurate. however, if you do it through many averages, the margin of error disappears.
For example, if a fillup fills more than usual, that means the calculated mileage will be less. however, for your next tank, since you'll have more gasoline due to slight overfilling, your calculated mileage will be overestimated. Through many measurements, when you average it out, the inconsistencies of each individual fillup will cancel out.
Old Jul 25, 2007 | 09:14 AM
RedAndy's Avatar
Very true. As with most things, the more data points you have, the better
Old Aug 3, 2007 | 06:25 AM
TomPer's Avatar
Gas Mileage Tracker
If you go to Gas Mileage Tracker - Software to track MPG on several cars. you can download a free program to help you track your mileage (MPG) and gas usage. I've been using it for three weeks and it's great for keeping track of what you spend, how much gas you've used, etc.
Old Aug 16, 2007 | 10:44 AM
BigDozer66's Avatar
Cool
That looks like a neat spreadsheet to play with or use in a serious way.
Thanks for sharing it.
BigDozer66
mikejet
Sep 7, 2010 08:50 AM
kortnie
Nov 10, 2008 04:33 AM
pwnstar
May 28, 2008 12:38 AM
gummyrabbit
Nov 28, 2007 10:43 PM
treadLightly
Jul 31, 2007 01:00 PM
