stock internals
Old Jul 19, 2007 | 09:53 AM
blackgd3's Avatar
Senior Member
stock internals
"all in all, psi is not your measuring tool to where u designate your stock "limit", its HP value. 12psi from Company X turbo may only give 210whp, which is still relatively safe on these L-series. past the 250whp mark is where i'd start thinking about build. Most companies are putting smaller turbos with their kits anyways." quoted from 03DSM-RSX, hope its ok with you
So to serve as a guide for all those who are planning to boost their l15a, how much can the stock internals take? Is 200 whp really safe? So no problems with highboost so long as I stay in this range right?
Old Jul 19, 2007 | 12:35 PM
manxman's Avatar
blackgd3-
O3DSM will probably answer you too, but from my knowledge, the answer to your question is YES. Increasing whp with intake mods is safe until you exceed the strength of the the engine's bottom end components- crankshaft, main & rod bearings, connecting rods & wrist pins and pistons.
Doubling the power output with boost components, properly designed, installed and adjusted would cause no problems. Add any more than that, you would be better off with a rebuild with higher strength bottom end parts. Even at that, it would be a "try it and see what happens" with no guarantees if you do this on your own. A professional engine builder would know in advance which brand of crank, forged pistons, etc. could be counted on to withstand the added pressures of radical modifications for power.
After that, you would have to have someone to follow you around to pick up the pieces of your transmission.
Old Jul 20, 2007 | 02:47 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
10.8 compression ratio is still relatively safe with boost. the higher compression=more power easily. lower compression will require more boost to make the same power, but gives a bigger margin for error.
yes, 200whp is def safe on the l15. be sure you have a competent tuner and using the correct tuning system. its critical to your engine's reliability.
Old Jul 20, 2007 | 05:28 AM
dank24's Avatar
x2, a good tune can get you good safe numbers. I am not all familiar with the L series yet. But what is used to manage it? I know k-pro was used on em2's,rsx's ,ep3's basically all k's and some 7th gen d's. Just regular emanage i am guessing, and I have seen srt-4's well above the 450whp mark tuned on emanage.
Old Jul 20, 2007 | 06:01 AM
blackgd3's Avatar
Senior Member
Thanks for all the help guys! I hope I reach my target though I will be using an e manage blue and I do know a very good tuner.
Old Jul 20, 2007 | 01:21 PM
jbrisson's Avatar
I'm curious to know if any of the R18 or R16 parts from the 2006 Honda Civic would fit into the L15A, with some minor machining. It has stronger internals.
Old Jul 22, 2007 | 05:25 AM
03DSM-RSX's Avatar
do NOT use emanage blue. the tuning capabilities on that unit are very limited.
i'm currently using emanage ultimate on my brother's supercharged scion tC and i can tell you it is worlds different from the Blue. Safer tuning parameters and fail-safes can be programmed via EMU.
EMU is by far the closest thing to a standalone system that is within a reasonable price. Motec, Unichip, etc are too complicated for your regular hobby-tuner.
Tuning is the most critical, do not cheap out on it in any way.
Old Sep 27, 2007 | 01:15 AM
gloryhound's Avatar
hey 03DSM-RSX (sorry to thread jack) but i was wondering what you think about getting the jackson s/c kit (if and when it comes out)... i really want that little bit of extra hp but my fit is my primary car and i dont want to damage it...
do you think its safe to get or will it invariably damage the engine?
Old Sep 21, 2023 | 08:02 PM
2010hondafit's Avatar
Stock internals
I just blew my engine at around 9psi boost on stock internals. Im around 185whp in my ge8
Old Oct 23, 2023 | 09:02 PM
Mike2306's Avatar
Definitely u have someone wrong maybe on your tuned! What turbo kit are u running?
Old Oct 28, 2023 | 04:21 PM
mykizism's Avatar
Do you know exactly what blew on your engine? Rings lands , connecting rod?
Old Oct 28, 2023 | 04:22 PM
mykizism's Avatar
It's not surprising that the engine blew.. the connecting rods on the L15A7 are the weak link.. the diameter of the bolts that hold the connecting rod caps are the same size as a 10mm bolt that hold in your fenders.
Old Nov 11, 2023 | 01:55 PM
Mike2306's Avatar
I have a 2007 fit L15a1 boosted with t25-t28 turbo at 9psi, today it's a big day for tuned with e85 also I want to increase 1-2 more psi, do u think to support 11psi my engine? 122k miles
UnicycleWheelie
Oct 23, 2023 09:03 PM
Lyon[Nightroad]
Jul 8, 2011 09:51 AM
revd34
Feb 7, 2010 03:55 AM
Starfox3
Aug 14, 2008 06:32 PM
kevin6767
32
Apr 18, 2008 12:11 AM
