throttle position sensor
Old Jul 25, 2007 | 11:12 AM
bigtymer8700's Avatar
Does anyone know where the TPS wire is located.... along witht the tach wire?
Old Aug 10, 2007 | 09:40 PM
bump bump bump bam!
Old Aug 18, 2007 | 02:03 PM
AJ PwR Jr.'s Avatar
Former Vendor
It is on the 17P connector D pin no.6, purple in colour.
Good luck
Old Aug 21, 2007 | 11:13 PM
you are the best
Old Mar 19, 2008 | 08:23 PM
can you take a picture of that cuz i remember someone telling me it was behind the throttle body and it was a red with black line wire.
Old Mar 19, 2008 | 08:27 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
The throttle body only has 1 plug going to it, I think? Cant be that hard to find, I wouldnt know because Ben could be talking about a 17pin clip at the ECU?
Old Mar 19, 2008 | 08:33 PM
yea and the ecu is on the passg. side... but im there is a plug behind the throttle body that has a plastic cover over it. I believe its a 6 pin connector w/ yellow/red blue, red/black and a couple other wires. But i think the red/black one is it.
Old Mar 19, 2008 | 08:37 PM
Posts in the NUUDE
I remember the plug on the TB but not how many wires are on it. 6 seems right.
Ive replaced my TB due to stupidity. *Puts head down*
Old Mar 19, 2008 | 08:42 PM
Haha yea you shoulda seen me today i thought i was gonna have to get a new top end for a second
Old Mar 19, 2008 | 08:44 PM
i think it was 07tafeltafit that told me where it was last time i just deleted the message like a tard
Old Mar 19, 2008 | 08:48 PM
Posts in the NUUDE
What exactly do you need this info for?
I was dumb and ported my TB. Hahahah! Thats why I know about the OEM TB.
Its deff. not cheap.
Old Mar 19, 2008 | 08:51 PM
trying to finishing running my zex kit but i think i might have tapped the wrong wire for the TPS. so stuck on this step already installed window switch fuel lines and ran the lines... im hoping i just tapped into the wrong wire and my NMU box isnt messed up.
Old Mar 20, 2008 | 02:29 AM
quangalang's Avatar
the D6- purple wire is not the throttle positioning wire. The Fit ECU communicates with the electronic throttle module using a serial bus, so there isn't a standard 0-5V sensor that will tell you the actual throttle position. The next best thing would be to use the accelerator pedal position sensor (pin D6). Just realize that the electronic throttle doesn't always follow the accelerator position directly: some stock ECUs will open or close the throttle if they think the MAP sensor voltage is too high or too low.
Old Mar 20, 2008 | 11:58 AM
wheres that located at in the engine bay or under the ecu?
Old Mar 20, 2008 | 01:31 PM
quangalang's Avatar
on the ecu plug D pin number 6
Old Mar 20, 2008 | 02:34 PM
so thats just the accelerator position not the tps but it will work the same? have you done the same set up?
Old Mar 20, 2008 | 03:07 PM
quangalang's Avatar
yeah that's what im using for TPS signal, it's pretty accurate but just remember that it's not always accurate
Old Mar 21, 2008 | 07:12 PM
lol scaring me there w/ it not being always accurate its for the TPS sensor on the ZEX box. So does anybody know what the red wire with black line is on that 6pin connector behind the throttle body is then? cuz i have it spliced to there rite now but no worries not running it I will try to splice into that wire instead when i get off of work this weekened then.
Old Mar 21, 2008 | 08:48 PM
NIGHTHAWKSI's Avatar
you can also get the TPS wire from the harness that plugs into the throttle body. on the 8th gen civic, it is the first wire (pin1) red/black. i haven't looked at the fit yet, but it might be similar.
i found the throttle body TPS wire more accessible than the ECU plug.
Old Mar 21, 2008 | 09:04 PM
yea thats what i was saying my tps is behind the throttle body under a plastic cover and i spliced that same color one.... I hope my zex box isnt messed up.
