2000 HONDA CIVIC QUESTION
Old May 4, 2005 | 04:44 PM
Subhabrata Bhattacharyya
Guest
Posts: n/a
Hi,
60000 mile maintenance is due for my Honda Civic 2000, 4 door sedan. My
question is whether it is advisable to go to a mechanic who has a machine
that pressure cleans and fills the Transmission fluids (Colonial Auto, $449)
or go to another mechanic (Brown's auto, $320) who does not have that
machine and does it in the regular way.
My concern is that the torque lock converter oil will not get changed if it
is not pressure cleaned. However, Honda does not say anything about this
issue. Also, the pressure clean costs more money. The question is whether it
is worth it.
Group please help!
SB
SoCalMike
Guest
Posts: n/a
Re: 2000 HONDA CIVIC QUESTION
Subhabrata Bhattacharyya wrote:
> Hi,
what else is involved? thats a lot of $$$.
> is worth it.
> Group please help!
> SB
justinreigle (at) gmail (dot) com
Guest
Posts: n/a
Sounds to me like you're getting ripped off. The local Honda dealer
here charges 150 for full tranny service. They also use compressed air
to empty the fluid from the ATF cooler and T.C.. Takes them 25 minutes.
As SoCalMike asked, what else is involved? Full 60k service, tranny
fluid change included?
- Justin
jim beam
Guest
Posts: n/a
> Hi,
> is worth it.
> Group please help!
> SB
does your driving qualify as extreme service? if not, don't waste your
money. the fluid's good for 120,000 miles in normal service. taking it
to the /wrong/ service station & getting contamination from incorrect
fluid residues are far more of a risk than leaving "old" fluid in there.
Guest
Posts: n/a
It involves full 60 k service including all the fluids except the brake
fluids. They said they will flush the coolant which takes care of the
radiator and the heat core. Also, they will change the oil and the filter,
AT fluid, fuel filter, spark plugs. Also, general inspection.
So should I do it piece by piece? Some of the things like the air filter
etc. I changed myself and do not need to be changed.
I wanted to do it from one of the AAA authorized people to get my coupon
work!
SB
"justinreigle (at) gmail (dot) com" <justinreigle@gmail.com> wrote in
message news:1112756257.111602.63620@g14g2000cwa.googlegro ups.com...
> - Justin
SoCalMike
Guest
Posts: n/a
brake/clutch fluids, IMO are some of the most important. old fluid picks
up water from the air and helps promote rust. i change mine every 3
years, along with the coolant, plugs, air filter, oil/filter (if needed
at the time. the fuel filter should last a lifetime.
> work!
is your dealer AAA authorized?
> SB
>>- Justin
Guest
Posts: n/a
Yes, they are AAA approved.
SB
"SoCalMike" <mikein562athotmail@hotmail.com> wrote in message
news:Z4qdnRZ4RqFrH87fRVn-gA@comcast.com...
filter,
> > work!
> > SB
> >>- Justin
tonyd3773
Mar 12, 2008 05:53 PM
cmeisenzahl
Dec 12, 2006 03:16 AM
2001CivicEXSedan
May 2, 2006 10:39 AM
Jason
Jul 11, 2005 12:05 AM
Andrew
May 4, 2005 11:16 AM
