JDM/USDM difference
Old Aug 5, 2007 | 01:43 PM
fitinfit's Avatar
JDM/USDM difference
tried to search but found nothing...what's the difference between the usdm and jdm fit suspension wise, cause i saw ppl talking about the jdm coilovers wont work on usdm fits. thanks
Old Aug 5, 2007 | 04:34 PM
Illusive's Avatar
They will, but you will need to make some holes bigger for the bolts...
Old Aug 6, 2007 | 12:13 AM
fitinfit's Avatar
thanks for the quick reply
is it really tricky to do the modification, cause not a lot ppl with usdm fit have jdm suspension.
Old Sep 13, 2007 | 02:57 PM
argentouno's Avatar
How about lowering springs? do the USDM fit and the JDM fit have compatible lowering springs.
Old Sep 13, 2007 | 03:43 PM
redrumm's Avatar
what coilovers are jdm that wont fit?
Old Sep 13, 2007 | 05:06 PM
AJ PwR Jr.'s Avatar
Former Vendor
All of the JDM coil-over or shocks will not work. The bolt size which bolts to the knuckle, USDM uses 19mm while JDM uses 17mm. Plus if you get the JDM suspension to work, you will need to change the end-link as well.
Old Sep 13, 2007 | 11:52 PM
argentouno's Avatar
But, its ok to use USDM springs on a JDM Shock?
onetwothree
Mar 14, 2015 11:53 AM
6ick
Oct 3, 2011 01:07 PM
09blackfit
Dec 10, 2009 08:11 AM
juniortanamati
Jan 29, 2009 11:42 AM
kylerwho
Oct 25, 2008 03:22 AM
