Launching RPMS
Old Aug 16, 2007 | 02:00 AM
tonyd3773's Avatar
Smile Launching RPMS
Hey Everyone,
Quick question. What is the best RPM range to launch the Fit from a dig?
Thx for all the help..
Da Fitz...
Old Aug 16, 2007 | 07:00 PM
dank24's Avatar
3.5-4k rpm
Old Aug 17, 2007 | 10:54 AM
tonyd3773's Avatar
thanks
Thank u dank24
Old Aug 17, 2007 | 01:46 PM
MouthfulOfchris's Avatar
For the best launch, I wouldn't just drop the clutch and floor the gas. Back in the days I used to drag race, I found the best way was to ride the clutch a little. Here is basically what worked for me.
Raise the RPM's just above the point that the tires would spin if I dumped the clutch. When I launched, I would release the clutch as I squeezed the gas pedal in equal amounts. I would have the clutch fully released at the same time as I had the pedal fully floored. How quickly the pedals moved depends on how much traction I was getting. Basically I would use both pedals to keep the tires right on the verge of slipping while putting as much power down as I could and keeping the RPMs up.
It takes a little practice to work both feet and is a little hard on the clutch. However, it did help me to get some decent launches out of a FWD turbo Talon with too much torque that did not like to start with out lighting the tires up.
Old Aug 17, 2007 | 01:57 PM
tonyd3773's Avatar
Thanks for the detailed description. It kinda puts things into perspective. Practice makes perfect, that's what they say! Thanks again
IN2TURBOS
Feb 27, 2011 06:28 AM
blackndecker
Sep 30, 2010 03:21 AM
Giggles
Nov 26, 2008 01:49 PM
Bennet Pullen
Nov 20, 2007 10:15 PM
Gil554
May 3, 2007 07:37 PM
