what brand of engine oil is good for honda pilots?
Old May 4, 2005 | 04:44 PM
mike113
Guest
Posts: n/a
should i buy castrol or penzoil or valvoline oil. Which brand of oil do u
people think is good.
halo2 guy
Guest
Posts: n/a
Re: what brand of engine oil is good for honda pilots?
Mobil 1 full synthetic
"mike113" <michael_yu8@hotmail.com> wrote in message
news:9d4268be0cbb3fbab146a00497a8f7e2@localhost.ta lkaboutautos.com...
jmattis@attglobal.net
Guest
Posts: n/a
do u
I use Pennzoil 10W30 in the MDX, change every 4-6,000 miles.
If I switched to synthethic, I'd use Mobil One 0-W20. Yes, it's
showing better oil test numbers than 5W20.
If you use 5W20 dino oil, as recommended by Honda, abandon their oil
change interval. Testing shows this oil is shot at 3,000 miles.
disallow
Guest
Posts: n/a
Where did you find that info? I would be very
interested in seeing it!
t
y_p_w
Guest
Posts: n/a
Probably from used oil analysis. UOA can test for wear
particles, contamination, and viscosity loss/gain. If
an oil is shot, sometimes the VI improvers shear down and
no longer provide adequate protection. In other cases the
oil excessively thickens to the point where engine parts
can be oil starved at startup.
y_p_w
Guest
Posts: n/a
jmattis@attglobal.net wrote:
> > of oil do u
> it's showing better oil test numbers than 5W20.
Mobil is no longer marketing Mobil 1 0W-20. They still may be making
a 0W-20 for Honda (for the hybrids). However - there's now a Mobil 1
5W-20 on the market. Also - Mobil's datasheets show that Mobil 1
5W-30 is awfully close to being a 5W-20.
I suppose the problem some people are having with the "conventional"
5W-20 oils are that they seem to include short-lived anti-wear
additives to make it protect adequately. Mobil 1 probably doesn't
need as much and will maintain its antiwear properties longer.
What the heck is "dino" oil these days? Many "conventional" oils use
higher performance "Group II" base. Some may even be semi-synthetic
(even without being labelled as such), although the definition of
"synthetic" is a but murky these days. Ford's Motorcraft 5W-20 is
labelled as being "semi-synthetic", although it's unclear who makes
it for them (or if they change suppliers often).
jim beam
Guest
Posts: n/a
>>>of oil do u
that motorcraft stuff is abysmal. i was initially attracted to the
price & the "semi-synthetic" label, but all my seals started leaking
badly within a few hundred miles. as in the main seal was leaking onto
the exhaust so bad you'd leave a smoke trail through the car park. the
motor started getting real rattly after about 2500 miles too. i'm now
back on castrol & the leaking has all but stopped. 89 civic.
halo2 guy
Guest
Posts: n/a
So you take an 89 Civic and just put in synthetic? So I guess the fact that
your seals are bad in the first place doesn't really matter to you. The
only thing synthetic did was clean your engine and seals of crud that had
accumulated and now they are leaking. Put the old dino oil back in and
hopefully it will sludge up enough again to seal the engine up for you.
"jim beam" <nospam@example.net> wrote in message
news:1113278259.7339e2c5210367c0d0c4d61edad6e696@t eranews...
>>>>of oil do u
> that motorcraft stuff is abysmal. i was initially attracted to the price
> & the "semi-synthetic" label, but all my seals started leaking badly
> within a few hundred miles. as in the main seal was leaking onto the
> exhaust so bad you'd leave a smoke trail through the car park. the motor
> started getting real rattly after about 2500 miles too. i'm now back on
jim beam
Guest
Posts: n/a
>>>>>of oil do u
fact that
had
sorry to burst your little bubble, but castrol is semi-synthetic too.
it simply has a much better base & superior additive package than that
ford garbage. that's also why it doesn't leave the engine rattling like
a bag of nails. that ok for you?
y_p_w
Guest
Posts: n/a
> >>>>>of oil do u
making
Mobil 1
"conventional"
oil
use
semi-synthetic
makes
price
badly
the
motor
back on
> fact that
you. The
that
> had
in and
you.
that
like
What the heck is "synthetic" these days? I'm getting the feeling that
in order to get decent performance out of a 5W-20, even the so-called
"conventional" 5W-20 oils are using some Group III or PAO base oils.
As for Castrol - they're rumored to used older "Group I" base oil for
most of the Castrol GTX lineup, while most others have gone to more
advanced "Group II". Pennzoil calls their base oil "PureBase", Chevron
uses "IsoSyn", while others just say "group II".
jim beam
Guest
Posts: n/a
y_p_w wrote:
> jim beam wrote:
>>>news:1113278259.7339e2c5210367c0d0c4d61edad6e69 6@teranews...
>>>>>>>of oil do u
> making
> Mobil 1
> "conventional"
> oil
> use
> semi-synthetic
> makes
> price
> badly
> the
> motor
> back on
>>fact that
> you. The
> that
>>had
> in and
> you.
> that
> like
good observations. the only thing we know for sure is that these words
are the product of the marketing department, not the lab.
while something like castrol gtx may not be the best of the best, from
my viewpoint, any oil that can clean the crud out of old engines like so
many of the clunkers i've had leaving them looking pretty much deposit
free, any oil that does not leave your engine sounding like an old tin
can being kicked around by a couple of kids, any oil that does not make
an old motor leak like a marine oil spill disaster, has /got/ to be
worth serious consideration.
Pars
Guest
Posts: n/a
I used to only use Castrol over a decade ago when I was driving an Old rear
drive Cutlass Supreme V8 (when all 4 barrel opened up on that carburetor,
that car could chase down just about anything on 4 wheels). So, the engine
was in great shape, event though the rest of the car was quickly
disintegrating. That was awhile ago and the Castrol might have been good for
the older engine, but my comparatively newer 98 Civic runs just as well on
the Mobel 1 (230,000km of aggressive driving and no rattles on cold
startup). In the case of Jim's 89 Civic, the Castrol might be the better
choice then the Mobel-1, since the older engine (with loose seals) might
have hard time retaining it...
Pars
Alex Rodriguez
Guest
Posts: n/a
In article <9d4268be0cbb3fbab146a00497a8f7e2@localhost.talkab outautos.com>,
michael_yu8@hotmail.com says...
I usually buy the brand name oil that is on sale and meets the manufacturers
recommendations. I never had an oil related problem following this procedure.
Alex
y_p_w
Guest
Posts: n/a
Alex Rodriguez wrote:
> In article
> >of oil do u people think is good.
> manufacturers recommendations. I never had an oil related
I took my car to my favorite Japanese car specialist today. For
years they've had a prominent Castrol GTX sign and said that they've
used it. However - I saw their shipment of Honda supplies stacked
up against a wall. It included several cases of Honda Z1 ATF and
Honda branded 5W-20 motor oil.
I understand that American Honda's oil supplier is Mobil. I don't
know if it's really a "specialty formula" for Honda. I rented a
Mazda 6 last Dec from Hertz. It included a sticker from a quickie
lube place saying that the last change was performed with Mobil
5W-20.
Eugene.Atget
Dec 11, 2010 07:21 PM
Benggolf
Jun 26, 2009 06:57 PM
phil_qc
Sep 6, 2006 01:23 PM
harry
Oct 16, 2005 01:31 AM
mike113
May 4, 2005 11:16 AM
