OE Steelies Weigh? The answer is ...
Old May 4, 2005 | 04:44 PM
Charles Lasitter
Guest
Posts: n/a
After quite a bit of searching, I found this site:
http://www.wheelweights.net/
Which has mostly only alloy wheel weights, but just enough info on
steel wheels to approximate the weight of 15x6.5 wheels at 22 pounds.
It also means that affordable alloys (carefully selected) can give
you a savings of unsprung weight of about:
OE: 7# (Alloy=15)
+1: 6# (" =16)
+2: 5# (" =17)
Then, again by carefully selecting the replacement tire for Michelin
MXV4 S8s, you could go up in wheel size and STILL have less unsprung
weight!
-- CL.
| Charles Lasitter | Mailing / Shipping |
| 401/728-1987 | 14 Cooke St |
| cl+at+ncdm+dot+com | Pawtucket RI 02860 |
Steve Bigelow
Guest
Posts: n/a
Re: OE Steelies Weigh? The answer is ...
"Charles Lasitter" <check.sig4@ddress.com> wrote in message
news:Xns963578879658clncdmcom@68.1.17.6...
> OE: 7# (Alloy=15)
> +1: 6# (" =16)
> +2: 5# (" =17)
> weight!
Still don't want to use the bathroom scale, huh?
Tire rack lists tire weights for those tires...a 195/65-15 is 20 lbs.
Charles Lasitter
Guest
Posts: n/a
"Steve Bigelow" <stevebigelowXXX@rogers.com> wrote in
news:nLidnchFNYZHa8ffRVn-ow@rogers.com:
I would have, but the folks at the local salvage yard didn't answer
the phone. Besides, I was impressed by the resource.
> Tire rack lists tire weights for those tires ... a 195/65-15 is 20
> lbs.
Tire Rack Lists the weight for LOTS of tires, and there is a very
significant variation to be found in tires of supposedly the same
size.
The load ratings and speed ratings seem to have significant influence
between tires of the same size, but it also varies substantially from
manufacturer to manufacturer.
The stock 205/65HR15 with a load index of 92 is 21 pounds, and it's
fairly light for a grand touring all-season tire. The Turanza LS-H,
and LS-V tires are 25 pounds. (They give you a full 11/32") But the
Turanza LS-T (92T) is only _20_ pounds. Go figr!
Now this all assumes the Tire Rack numbers are accurate, and that may
be assuming too much ...
There are a lot of interesting numbers on the Tire Rack web site. I
just wish I had a better feel for the laws of diminishing returns as
it applies to unsprung weight, and rubber on the road.
If you could be two pounds lighter on the corners or have an extra
half inch of rubber on the road what would you choose? I'm cornering
on a lot of choppy, uneven pavement, and on the margin, I don't know
what I should maximize.
-- CL.
merlotbrougham@hotmail.com
Guest
Posts: n/a
Charles, I've been sorta following all your inquiries about wheels and
tires. I have a '92 Civic EX that I'd love to upgrade with a package
from TireRack. What model are you upgrading? Have you googled honda
performance groups? I'd bet there are a ton of west coast tuner guys to
give advice from experience.
Guest
Posts: n/a
and
to
Whoops- I see it's a newer Accord.
Charles Lasitter
Guest
Posts: n/a
merlotbrougham@hotmail.com wrote in news:1113339722.681049.199500
@z14g2000cwz.googlegroups.com:
Yes, but the relevant theory still applies.
I think you can learn a great deal with (a grain of salt) studying the
tables and numbers that the Tire Rack has compiled. They could be
better, without a doubt, but for free, they beat the hell out of
nothing at all.
-- CL.
SSR Wheels
Nov 24, 2014 01:01 PM
YeeFit
Car Shows, Events, and Racing
74
Jul 21, 2009 06:57 PM
john21031
Apr 28, 2009 09:27 PM
VistaXP
Jun 23, 2008 05:09 PM
Charles Lasitter
May 4, 2005 04:44 PM
