Misfire with my 91 Accord EX
Old May 4, 2005 | 04:44 PM
Steve
Guest
Posts: n/a
Recently, my 91 accord EX, when it is warmed up, started sputtering when
I press the gas pedal very slightly. I.E. when I am going through a
parking lot under 20 KM per hour. If I accelerate more aggressively but
not excessively, everything is great. All other times it appears to be
normal, just when starting off with a gentle foot. This has been
happening for about 1 month.
New Parts:
Plugs
Wires
Cap and rotor
Checked air filter
Fuel tank Injector cleaner
Any advise?
Steve
Ottawa Ontario
disallow
Guest
Posts: n/a
Re: Misfire with my 91 Accord EX
whats the tension on your timing belt? Has it
skipped a tooth?
t
jim beam
Guest
Posts: n/a
> New Parts:
> Plugs
> Wires
> Cap and rotor
> Checked air filter
> Any advise?
> Steve
> Ottawa Ontario
replace the thermostat with a new oem one. cured similar symptoms in my
'89 civic. make sure coolant level is correct too - look in the rad,
not the expansion bottle. checking the timing won't hurt either.
motsco_ _
Guest
Posts: n/a
> New Parts:
> Plugs
> Wires
> Cap and rotor
> Checked air filter
> Any advise?
> Steve
> Ottawa Ontario
If you crawl around a parking lot in first, does it try to 'buck' a bit?
If so you probably have a shot Throttle Position Sensor. Do a
Google.com search. look under 'groups' too. Knowing your mileage would
help. . .
'Curly'
To REPLY: If there are a couple of underscores in my return address,
you must remove them to reply directly . . . . . . Thanks.
Regarding stage performances: When everyone else has finished playing,
you should not play any notes you have left over. -
jim beam
Guest
Posts: n/a
motsco_ _ wrote:
>> when I press the gas pedal very slightly. I.E. when I am going through
>> a parking lot under 20 KM per hour. If I accelerate more aggressively
>> but not excessively, everything is great. All other times it appears
>> to be normal, just when starting off with a gentle foot. This has
>> been happening for about 1 month.
>> New Parts:
>> Plugs
>> Wires
>> Cap and rotor
>> Checked air filter
>> Any advise?
>> Steve
>> Ottawa Ontario
> help. . .
> 'Curly'
good point - check for computer codes. tps always shows up as a code if
it's failing.
Steve
Guest
Posts: n/a
No it doesn't buck but misses...like one plug is misfiring. As soon as
you load the engine by accelerating, it works great. If I hadn't put
new plugs and check the gap I would have suspected this. The car has
263,000kms and works great. It an automatic.
I've reset the computer to clear any faults and there are no faults
showing during the diagnosis test..
>> through a parking lot under 20 KM per hour. If I accelerate more
>> aggressively but not excessively, everything is great. All other
>> times it appears to be normal, just when starting off with a gentle
>> foot. This has been happening for about 1 month.
>> New Parts:
>> Plugs
>> Wires
>> Cap and rotor
>> Checked air filter
>> Any advise?
>> Steve
>> Ottawa Ontario
> bit? If so you probably have a shot Throttle Position Sensor. Do a
> help. . .
> 'Curly'
Michael Pardee
Guest
Posts: n/a
"Steve" <dudkas@sympatico.ca> wrote in message
news:42696D0A.7070509@sympatico.ca...
> you load the engine by accelerating, it works great. If I hadn't put new
Persistent single-cylinder misfire at low throttle (often does it at idle,
too, but with fuel injection that isn't always true) makes me think of a
vacuum leak first of all. In the Days Of Olde that usually meant the PCV
hose or vacuum advance connection (since they typically came off a single
branch of the intake manifold) but nowadays the fuel injector seat seal is
suspect. A gentle squirt of carburetor cleaner around the base of each
injector when the engine is idling will cause the idle speed to blip if you
hit a leaky seal.
As always, use carb cleaner cautiously on a running engine - it is made to
be flammable. The smallest squirt that will wet the seal is what you want.
Mike
Jafir Elkurd
Guest
Posts: n/a
Is it a automatic? If so, hold your left foot on the brake, put it in
drive, and with you right foot bring up the RPM. Does it miss then? Is it
always at the same spot that it starts? If so, turn the engine off. Bypass
the vacuum hose going to the EGR valve and try again (you'll get a check
engine light this time, but don't worry about it). If it goes away, you
have plugged EGR ports in your intake manifold.
news:mgZ9e.8943$9G.657082@news20.bellglobal.com...
> Recently, my 91 accord EX, when it is warmed up, started sputtering when I
> press the gas pedal very slightly. I.E. when I am going through a parking
> lot under 20 KM per hour. If I accelerate more aggressively but not
> New Parts:
> Plugs
> Wires
> Cap and rotor
> Checked air filter
> Any advise?
> Steve
> Ottawa Ontario
rastapasta
Guest
Posts: n/a
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:42687F47.3030406@interbaun.com...
>> New Parts:
>> Plugs
>> Wires
>> Cap and rotor
>> Checked air filter
>> Any advise?
>> Steve
>> Ottawa Ontario
> If so you probably have a shot Throttle Position Sensor. Do a Google.com
> search. look under 'groups' too. Knowing your mileage would help. . .
> 'Curly'
Hey---sorry to jump in here, but this is what happens with my '92 Teg (RS I
think). On low gears, it'll "buck" as you describe. Will this work on my
non-VTEC engine (if this is the problem)?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
thnx
> To REPLY: If there are a couple of underscores in my return address, you
> Regarding stage performances: When everyone else has finished playing, you
Old May 15, 2005 | 07:30 PM
SJD
Guest
Posts: n/a
Steve wrote:
For everyone who replied, I lost all the great info. If you have any
ideas on this problem please reply again.
Sorry, my HD died and I lost all the PM you sent.
Thanks
Steve
>>> New Parts:
>>> Plugs
>>> Wires
>>> Cap and rotor
>>> Checked air filter
>>> Any advise?
>>> Steve
>>> Ottawa Ontario
>> help. . .
>> 'Curly'
SJD
Guest
Posts: n/a
I tried the first part and yes, it is around 1200-2000 RPM then smooths
out. I suspect it is the throttle position sensor or blocked EGR port.
I will try this on the week-end.
Steve
>>New Parts:
>>Plugs
>>Wires
>>Cap and rotor
>>Checked air filter
>>Any advise?
>>Steve
>>Ottawa Ontario
Steve Bigelow
Guest
Posts: n/a
EGR port cleaning are a relatively easy DIY, if you get yourself a
slidehammer.
"SJD" <dudkas@sympatico.ca> wrote in message
news:42855429.6030902@sympatico.ca...
> out. I suspect it is the throttle position sensor or blocked EGR port. I
> Steve
>> it always at the same spot that it starts? If so, turn the engine off.
>> Bypass the vacuum hose going to the EGR valve and try again (you'll get a
>> check engine light this time, but don't worry about it). If it goes
>> away, you have plugged EGR ports in your intake manifold.
>>>New Parts:
>>>Plugs
>>>Wires
>>>Cap and rotor
>>>Checked air filter
>>>Any advise?
>>>Steve
>>>Ottawa Ontario
DaveR
Jun 3, 2005 01:06 AM
CIDW
May 15, 2005 07:30 PM
Enrique Gonzales
May 4, 2005 04:44 PM
Bill
May 4, 2005 11:16 AM
gireesham@yahoo.com
