Weathertech Window Visors
Old Oct 1, 2007 | 11:55 AM
saralee's Avatar
Does anyone have a set of Weathertech Window visors installed? I would like to make a decision soon between the authentic Mugen or the Weathertech but I haven't seen anyone with the Weathertech visors. I would love to see an actual picture from someone here on FitFreak.
Thanks
Old Oct 1, 2007 | 12:12 PM
manxman's Avatar
Thanks
In the "visor" thread, another member said that he has this brand on his Fit and that they work just fine. I have used this brand on other vehicles with MUCH larger windows, and they were OK. But due to warnings about bad fitment and window leaks, Zeta Products stopped carrying the brand.
While I was shopping for my visors I went to the WeatherTech site, and found that a 4-pc. set for the Fit was about the same price as the Mugens. When I was able to look at the Mugens on a Fit at a recent Fit Meet, I decided not to gamble on the WeatherTech brand. But for your decision, it's pretty likely that if you buy them on-line from someplace like ajprindle.com or other car accessory outlet, you can return them for a refund if they aren't damaged.
Good luck!
Old Oct 1, 2007 | 12:32 PM
saralee's Avatar
Thanks manxman for your input.
From what I've read, both are functional products that do the job well, but I am also concerned about the aesthetics that's why I wanted to see a picture of the Weathertech set.
How do you remove the 3M adhesive tape if you have to remove the Mugens?
I will probably go the route of ordering the Weathertech from Parts Source and see how they work and look.
Anyone else have pictures?
Old Oct 1, 2007 | 03:06 PM
aliencowboy's Avatar
If you remove the visors, WD-40 and elbow grease will remove the glue.
Old Oct 1, 2007 | 10:06 PM
nsx280ps's Avatar
We have a 2006 accord and 07 fit.... got weathertechs for both.... for 1 day then returned both...... both created more windnoise since it goes between the window seal... and if left too long i think it will stretch your seals permanantly
Old Oct 1, 2007 | 10:28 PM
Fish's Avatar
I also had the weathertech visors. They were a gift. The front fit alright, but the window motor seemed to strain more due to the visors being wedged in behind the window seal. I never got the rear ones installed, they weren't cut correctly and they would only go halfway in. I even took them to the place where they were purchased and they couldn't install the rear ones and they refused to give me a refund because the fronts were installed.
As far as removing the double sided tape there are plenty of adhesive removing products out there. And WD-40 works great too.
I would go for the Mugen's, but it's up to you.
Good Luck.
Old Oct 2, 2007 | 01:47 AM
zer0sk8ordie's Avatar
i had weathertechs on my integra and one day i had both windows down and one flew off! it sucked!
Old Oct 2, 2007 | 02:33 AM
kenken's Avatar
This is what I installed, OEM Mugen Style which also 100% fit size and much much cheaper than the original Mugen ones.
This is a pic from my friend using the same one I am using
Old Oct 2, 2007 | 09:28 AM
scottjef's Avatar
I agree with NSX280PS - I bought the Weathertechs and installed them (no installation problems) for as long as it took to go out on the freeway and hear the increased wind noise that resulted from them. The wind noise combined with the uncomfortable feeling I got about breaking the window seal were enough to make me take them off and they're sitting on a shelf in the garage now. After this experience I decided I didn't need window visors after all so I didn't try any of the glue-on kinds.
Old Oct 2, 2007 | 09:50 AM
saralee's Avatar
Thank you everyone for your input! I've decided not to get the Weathertech.
It's down to JDM or Mugen! I really like the JDM slim profile vs the obvious styling of the Mugen. Which one will be more aerodynamic in terms of wind noise and allowing air to flow inside the car? Can anyone tell me how far the Mugen extends out from the door?
Old Oct 2, 2007 | 01:43 PM
grimm79's Avatar
I have them installed in my Fit and they are nice. The two in the back seat fell out a week or two ago. I bought some adhesive and put them in last week and they didn'i fall out yet.
Old Oct 2, 2007 | 04:25 PM
nosewitdot's Avatar
would these be the Mugen or weathertech ones?
Old Oct 3, 2007 | 10:54 AM
baldddguy's Avatar
I have the Weathertech visors. The shop where I bought them recommended them over another brand that were attached with tape.
The salesman had them on his pickup.
I've had them for a month with no problems.
Old Oct 3, 2007 | 11:06 AM
saralee's Avatar
For those who have Weathertech visors, please put up some pictures! We FitFreakers do care about looks and styles.
Some pictures will let us compare the look to Mugen and OEM styles.
Old Oct 3, 2007 | 08:38 PM
kenken's Avatar
Mugen visors outlook is exactly the same as the one I post in my message. The only different is OEM does not have the "Mugen" logo.
If you guys found your OEM visors easily peel off, I suggest you tear them off completely, use alcohol or window cleaners to clean both the visors and the car until no more tapes left on the surfaces, then use 3M outdoor black double sided tape to stick on.
Mine used for 3 years already and still completely fit sticking on my Jazz
Old Nov 2, 2007 | 10:23 PM
yeeman's Avatar
Thanks
One of my rear WeatherTechs flew off, so I had 2 more sent to me & hoped they would both "seat" into the window channel better....no luck....they still pull out because they're not cut right. I'm sending them back for a refund.
Old Nov 3, 2007 | 06:32 AM
spreadhead's Avatar
I had to "trim" mine to get them to seat properly.
Old Nov 3, 2007 | 11:04 AM
noyzz's Avatar
I love my weathertech visors!!!!! I didn't want the stick on ones so I went with them plus I like how far they come down for the front doors......I've had mine for 3 months now and no problems yet! If you go to the SSM thread theres pix of my fit with them on...hope that helps?
Old Nov 4, 2007 | 05:25 PM
743power's Avatar
I've had the weathertechs on for 4 months now. The rears don't fit 100%, but I haven't had any sort of problems with them coming loose or anything. As for the wind noise, it is GREATLY REDUCED, not increased, and with all 4 windows down on the highway, the car no longer makes that scary pulsing sound that shakes the whole car. For $90 you can't go wrong. The ONLY fault they have is the fitment of the rears. They "bubble" out a bit further than I'd like, because of how the corners are moulded. I have thought about contacting them about it, but it's not really worth my time.
Old Nov 4, 2007 | 07:01 PM
yeeman's Avatar
Yeah, I've contacted MacNeil about them, but they couldn't give me any advice, so, I'm sending them back.
Even if I filed down the back ones so they fit better, I'd still be concerned about them flying off again.
El Cohño
Apr 30, 2018 04:26 PM
max503
Apr 28, 2016 12:07 AM
chriscurtain420
Mar 7, 2012 04:51 AM
yurpleFITTED
Jun 20, 2010 07:05 PM
pastadog
51
Feb 25, 2008 06:45 PM
