Water pump selant required beside rubber gasket?
Old May 6, 2005 | 11:47 AM
Gerry
Guest
Posts: n/a
Haynes manual states to use RTV sealant in addition to the rubber
gasket. Helmes manual does not say to use rtv sealant. What do you
use?
justinreigle (at) gmail (dot) com
Guest
Posts: n/a
Re: Water pump selant required beside rubber gasket?
I always use a small amount of RTV selant. The instructions for
installing
the waterpump usually also recommend the RTV. I use a small bead of the
red
stuff right on top of the rubber gasket. Make sure the engine-side
mating
surface is nice and clean.
- Justin
motsco_ _
Guest
Posts: n/a
> use?
A light film of silicone _grease_ is what I use, on the engine side,
otherwise you've got all kinds of gunk to scrape off next time you're in
there. If Honda thought glue was necessary, it would have been there
from the factory. They have this annoying concept of making parts fit
correctly without glue.
'Curly'
MTLian
Sep 30, 2014 03:29 PM
davela72
May 14, 2009 05:17 PM
grouser
Jul 26, 2007 11:28 PM
sy11580
Jul 11, 2006 07:06 AM
mmdir2005@yahoo.com
Oct 11, 2005 11:36 PM
