'90 Civic Rear Suspension Clunk
Old May 9, 2005 | 01:49 PM
WaterWatcher
Guest
Posts: n/a
I have a '90 Civic LX and the rear suspension makes a clunk or knocking
noise, usually when braking It also makes a creaking noise when going over
bumps. It has 102,000 miles on it. I know my trailing arm bushings are
cracked and that I need to replace them. My question is, would worn
trailing arm bushings cause a clunk or knock? I know that they could cause
creaking noises, but knocking or clunking? If you know that that is likely
caused by worn trailing arm bushings, or wouldn't, please respond.
Thanks,
WW
TeGGeR®
Guest
Posts: n/a
Re: '90 Civic Rear Suspension Clunk
"WaterWatcher" <replytogroup@donotmail.com> wrote in
news:ENOdnZ8ytrTWreHfRVn-uw@comcast.com:
> knocking noise, usually when braking It also makes a creaking noise
> when going over bumps. It has 102,000 miles on it. I know my trailing
> arm bushings are cracked and that I need to replace them. My question
> is, would worn trailing arm bushings cause a clunk or knock? I know
> that they could cause creaking noises, but knocking or clunking? If
> you know that that is likely caused by worn trailing arm bushings, or
Would.
TeGGeR®
www.tegger.com/hondafaq/
codenamezero
Jun 25, 2014 12:03 PM
flipwidwings
May 12, 2012 07:41 PM
txmatt
Aug 17, 2011 03:48 PM
hyperfit
Mar 19, 2011 03:29 PM
Henry
Aug 4, 2005 08:31 PM
