Life saving driving tips
Old May 10, 2005 | 11:42 AM
Steve Bigelow
Guest
Posts: n/a
Re: Life saving driving tips
"Jason" <jason@nospam.com> wrote in message
news:jason-0905051640480001@pm4-broad-13.snlo.dialup.fix.net...
> If your gas pedal sticks--follow the advice above. However, you should use
> your regular brakes to come to a stop.
You might want to just turn off the damn engine, instead of taking your
advice, and slipping a full throttled engine into NEUTRAL!
bearman
Guest
Posts: n/a
"Steve Bigelow" <stevebigelowXXX@rogers.com> wrote in message
news:NuudnQT7HIS1YOLfRVn-gg@rogers.com...
use
Turning off the engine may deactivate the power steering and vacuum assisted
brakes.
Bearman
If it's got tits, tires, tubes, or transistors, it's trouble.
SoCalMike
Guest
Posts: n/a
> use
> brakes.
and depending on wheel angle and how flustered you are, it could lock
the wheel
Jason
Guest
Posts: n/a
In article <jason-0905051640480001@pm4-broad-13.snlo.dialup.fix.net>,
jason@nospam.com (Jason) wrote:
> I saw a news report today related to a school bus. The driver of the bus
> had a perfect driving record. He ran thru a stop light and caused a very
> very serious accident. The news reporter was not able to determine why the
> driver failed to stop at the light. Some people speculated that the gas
> pedal stuck or that his brakes failed to work.
> I realize that most people that subscribe to this newsgroup probably
> already knows these secrets. Even if you do know these secrets, please
> make sure that everyone in your family is informed of these secrets. I've
> talked to several people and only one person knew both secrets.
> The first secret:
> If your brakes stop working, remove your foot from the gas pedal. Place
> the gear shift in neutral. Use your signal light to let the driver behind
> you know that you are going to turn right. Drift off the road. Use the
> emerg. brakes to stop.
> Don't do what the bus driver probably done which was to crash the vehicle
> in order to bring it to a stop.
> If anyone wants to comment--feel free to do so.
UPDATE:
My advice only applies to cars, SUVs, pickups and any vans. It does NOT
apply to dump trucks or tractor trailors carrying full loads going down a
grade. If you own or drive such a vehicle--ignore my advice and get your
advice from experts in that field. I have no experience related to driving
fully loaded large trucks traveling down grades. I only wish that the
school bus driver mentioned above knew the tips that I mentioned. I don't
know why everyone is not required to learn these two tips in order to get
a driver's license.
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
Jason
Guest
Posts: n/a
The first secret:
Old May 15, 2005 | 07:30 PM
Randolph
Guest
Posts: n/a
Jason wrote:
<snip>
Best advice you have given so far.
Gordon McGrew
Guest
Posts: n/a
On Thu, 12 May 2005 09:08:10 -0700, jason@nospam.com (Jason) wrote:
>In article <6nl581dudkaffgdiqeho1cp0s6a1kjnatj@4ax.com>,
>gRmEcMgOrVeEw@mindspring.com (Gordon McGrew) wrote:
>> On Wed, 11 May 2005 12:42:12 -0700, jason@nospam.com (Jason) wrote:
>> >Even if you disagreed with my
>> >tips--I think that all of us can agree that we don't need to crash to stop
>> >when the brakes fail or the gas pedal sticks.
>> It's a last resort, but there may be circumstances which make a crash
>> unavoidable. Choosing what to hit may be your only option.
>Great point. This is especially true related to tractor trailors going
>down a grade. A trucker told me that once you push in the clutch or shift
>to neutral--that the truck starts moving really quick and it's impossible
>to get the truck into a lower gear without damaging the transmission. He
>even told me a funny truckers story:
>What to do if a truckers brakes stop working or
>the gas pedal sticks while going down a grade:
>1. Pray
>2. Put your head between your legs.
>3. Kiss your ass good bye.
My comment wasn't meant to be facetious - not sure if you took it that
way. Sideswiping a line of parked or stopped cars or even going
head-on into a traffic pole or other stationary object is a lot better
than rolling into an intersection at 10 mph when heavy cross-traffic
is going 50 mph. You have to judge the situation and make your best
decision when it arises.
Jason
Guest
Posts: n/a
1. Pray
Gordon McGrew
Guest
Posts: n/a
Jason
Guest
Posts: n/a
In article <d5t8v1$cka$1@theodyn.ncf.ca>, ag564@FreeNet.Carleton.CA (Dan
Beaton) wrote:
> Jason (jason@nospam.com) writes:
> >> The first secret:
> > UPDATE:
> > a driver's license.
> Speculation by uninvolved observers as to cause of an accident is hardly
> fact. You don't know that the driver ran through a stop sign. The driver
> may have had a heart attack and been dead when the bus went past the stop
> sign.
> In my part of the world, school buses are tightly regulated. They must be
> retired from servcie when only a few years old, and must be regularly
> maintained, with records kept of the mainteance performed. Complete brake
> failure is almost unknown in modern vehicles.
> Stalling that leads to loss of power assist on brakes and perceived
> brake loss is far more common. Stalling also leads to loss of power
> steering and the perception that the steering wheel has locked. In both
> cases, the brakes and steering are still functional but much more
> difficult to operate.
> Shifting out of gear is more likely to cause stalling. If the gas
> pedal is stuck on the floor, it could cause the engine to self-destruct
> before stalling. Bonus!
> Strategies for responding to various system failures while driving
> will depend on how the car is equipped, and driving conditions. No one
> size fits all.
> I will agree with you that many drivers are ill-equipped to deal with
> sudden failures, even as simple as a flat tire. Regular maintenance
> at a reputable shop is one way of reducing the risk. Better driver
> training would also help. Maybe before long, new drivers will be
> required to spend time in a true-to-life simulator before first
> getting behind the wheel.
> Dan
> (This account is not used for email.)
Dan,
The fact is that lots of drivers would panic if their brakes failed to
work or the gas pedal stuck. Those people that panic would probably end up
crashing their vehicles. I now realize that other people had some tips
that were in some cases better than my tips and in other cases worst than
my tips. I just wanted people to know that crashing the vehicle to bring
it to a stop is the worst thing to do. Even if you disagreed with my
Dan Beaton
Guest
Posts: n/a
>> The first secret:
> UPDATE:
> a driver's license.
sign.
size fits all.
Dan
Gordon McGrew
Guest
Posts: n/a
On Mon, 09 May 2005 22:28:16 -0700, SoCalMike
>> use
>> brakes.
>the wheel
I think that is the biggest risk. Power steering is mostly for low
speed parking maneuvers. There should be enough vacuum in the system
to provide braking assist to stop the car. Even without power brakes,
you should be able to safely stop the car under normal circumstances.
Of course, if you have a manual transmission and you leave it in gear,
you will not lose the power assist.
Just be careful not to turn the key any farther than necessary to kill
the engine.
Gordon McGrew
Guest
Posts: n/a
Your best action is dependent on circumstances in each case. If there
is plenty of room, an easy drift onto the shoulder and gentle
application of the e-brake may be all that is needed. However, if the
brakes fail at a critical time, I would start applying the e-brake
immediately and downshift into the lowest gear possible. Depressing
the service brake pedal will keep the brake lights lit if that is
important. If the situation is dire, sideswiping curbs, guard rails
or other vehicles may be necessary. Alternatively, steering to avoid
objects or at least pick the best object for impact may be the best
choice. It all depends on the circumstances.
Jason
Guest
Posts: n/a
In article <d5qrfh$528$4@newsmaster.cc.columbia.edu>, Alex Rodriguez
> jason@nospam.com says...
> These two scenarios are easily checked. Either one of these failures do
> not miraculously fix themselves during an accident.
> Secrets???? Why do you call them secrets? There is nothing about being
> a safe driver that is a secret.
> >The first secret:
> This is taught at all driver safety classes.
> The advice should not be the same. You should not shift into neutral as
> you might damage your engine. Just hit the brakes. It may take longer,
> but the car will eventually stop.
> Again, blind speculation with no basis on fact is plain stupid.
> Alex
Alex,
You made some excellent points. You are right--perhaps I should not have
used the term "secrets". Whenever there is a serious accident like the bus
crash--it's fairly common for people to speculate as to the cause of the
accident. For example, if there was a major wind storm, and you saw three
tractor trailors that were lying on their sides--I have a feeling that the
typical driver that passed the trucks would speculate that the wind caused
the trucks to be lying on their sides.
SoCalMike
Guest
Posts: n/a
gee- sorry i ran over ya. coulda stopped sooner but i was afraid of
blowing up my engine!
put it in neutral, and let the rev limiter do its thing.
Alex Rodriguez
Guest
Posts: n/a
>The first secret:
Alex
Tush Smells Bush Kills!!!!!!!!!!!
Guest
Posts: n/a
At least the bus driver had a safe driving record. A local news did an
expose of LA bus drivers and found that many of them are convicted
drunk drivers with suspended licenses.
Old Sep 27, 2010 | 05:30 PM
driving101's Avatar
Due to small mistake people have to lose their lives. They must learn driving lessons for safe driving. Driving school is best place to learn life saving tips. They teaches advance lessons and safe driving lessons to avoid these kind of mishappenings.
mxl180
Jun 18, 2010 05:09 PM
tuturosso
Nov 9, 2009 01:48 PM
The Right FIT
Jul 13, 2008 02:41 AM
bwb
Mar 17, 2008 06:05 PM
