How to check whether timing belt slipped on 88 Accord
Old May 15, 2005 | 07:30 PM
Misterbeets
Guest
Posts: n/a
Hi,
My 88 Accord DX auto suddenly won't run right--no power, barely idles,
stalls, backfires--and I want to see whether my overdue-for-a-change
80,000 mi timing belt has slipped. I plan remove the valve cover per
the Helm manual and check the cam pully marks when the flywheel mark
indicates TDC compression on #1 cyl. I've never seen the latter. Where
is this window? Helm doesn't show it. Any pointers?
Thanks,
JB
motsco_ _
Guest
Posts: n/a
Re: How to check whether timing belt slipped on 88 Accord
Misterbeets wrote:
> Hi,
> Thanks,
> JB
If it's like later Honda engines, the marks are on the outside edge of
the crankshaft pulley, and there's a pointer molded into the timing belt
cover. There's two marks on the pulley, one being TDC, and the other
will be (something like) 14 degrees BTDC. You look down with a
flashlight from above. Since you'll have a spark plug out, you'll know
which mark is which by the piston's position.. Keep in mind your TB
interval is max mileage OR max years, too.
'Curly'
Misterbeets
Guest
Posts: n/a
Thanks. Timing checked out OK. Did find some corrosion at a distributor
tower, and it runs fine again.
Old May 18, 2005 | 02:25 AM
Misterbeets
Guest
Posts: n/a
Better, but not fine. Definite loss of power and had to set idle higher
to keep from stalling. Possibly EGR stuck open. Will check into this.
Is there any chemical to clean it, or do you just scrape away carbon?
Jafir Elkurd
Guest
Posts: n/a
I'd check the advance mechanisms with the cap off. see if you can turn the
rotor a little. It should move fairly freely and snap back pretty quick.
Also check the vacuum advance diaphragm to see if it holds vacuum.... check
with both hoses disconnected.
"Misterbeets" <misterbeets@gmail.com> wrote in message
news:1116243272.972865.140280@g47g2000cwa.googlegr oups.com...
Old May 22, 2005 | 10:16 PM
Misterbeets
Guest
Posts: n/a
Good advice. One of the two plastic plugs inside the distributor, that
cover up the screws holding the plate, broke and was fouling the stator
blade, preventing any spark advance. I just removed it. Thanks everyone
else for all the suggestions.
And now I know my compression numbers, and I can think about putting on
a rebuilt head and installing new rings.
Old Jun 3, 2005 | 01:06 AM
Misterbeets
Guest
Posts: n/a
Oops.On further investigation, it was the rotor: Had a carbon button
underneath the arm that showed spark damage. $3 repair. Plastic plug is
back in, runs fine. Added Vavlemedic for sticky rings too.
Ray
Aug 10, 2005 08:36 PM
ksrogers
Jul 10, 2005 12:33 PM
richardbentz@gmail.com
May 18, 2005 02:25 AM
punkyw
May 15, 2005 07:30 PM
Matt
May 4, 2005 04:44 PM
