Wiring pinout for ELD,
Old May 15, 2005 | 07:30 PM
google@canadiangeek.net
Guest
Posts: n/a
I need the pin out for the Electronic Load Detector.
I have a Canadian Honda Civic (1996) that has no ELD. I have swapped
in a JDM B18C1 engine (Acura Integra GSR) and now my ECU has a light on
for ELD (Code 20)
I have purchased another fuse box from eBay that now has the ELD
connector however I do not know the order of the pins for inputs and
output.
1 wire is 12Volt + (Black/White)
1 Wire is Ground + (Black)
1 Wire is 5 Volt Output. (Red/Green)
Does anyone know the order of the wires?
Anyone in the USA should be able to just look at the bottom of there
fuse box. I'm sure someone in a shop has a harness lying around they
can look at.
Kevin McMurtrie
Guest
Posts: n/a
Re: Wiring pinout for ELD,
In article <1115921241.589751.35520@o13g2000cwo.googlegroups. com>,
> for ELD (Code 20)
> output.
> can look at.
I have the wire harness pinouts:
IG1 Black/White Pin 1 ELD
GND Black Pin 2 ELD
EL Green/Red Pin 3 ELD -> Pin 16 ECM/PCM Connector D
ELD 3P harness connector (C354):
| 1 | 2 | 3 |
I G E
G N L
1 D
I can't find a picture of the ELD in the repair manual so I don't know
what to do if it has solder lugs or a non-standard jack on it.
Guest
Posts: n/a
Thanks. I will give this a shot today.
it has a connector that is supposed to fit however I dont have the
connector so I will just use the leads as solder lugs.
AlphaQuad
Dec 8, 2019 04:36 AM
doctor J
Nov 27, 2017 02:20 PM
lilizm319
Apr 11, 2015 07:08 PM
noripwr
Oct 21, 2014 06:48 PM
lakia5524
Apr 21, 2014 09:59 AM
