Brighter License Plate Bulbs
Old Nov 16, 2007 | 01:22 PM
scarygoldlion's Avatar
Hello all. Happy Friday! Just changed my plate bulbs last night. Here are the pics of before and after also with the panel taken off. The whiter wedge bulbs make a nice and clean look. What do you guys think? Enjoy!
Old Nov 16, 2007 | 02:12 PM
smatts's Avatar
Honda Fit Forums Moderator
You can change your rear plate light bulbs without removing that piece, just reach up from the outside and push the light covers to the right. With a little force they will slide to the right and then you can pull down and remove them / switch them.
Looks good though.
Old Nov 16, 2007 | 05:14 PM
fitoromocto's Avatar
The procedure is also well explain in your owner manual
Old Nov 17, 2007 | 03:28 AM
azncarbos's Avatar
Change Light again. LoL Look sweet I 'm planning to change light later. but did change my reverse one w/ piaa and now blinding ppl as reverse.
Old Nov 17, 2007 | 11:49 AM
koolkevin1107's Avatar
Originally Posted by scarygoldlion
GOUDY HONDA FTMFW!!! The other posters are right, u don't have to remove the entire panel 2 get to it (Even tho that's what i did the first time also ) but if ur going 2 remove it the way the manual says, BE CAREFUL because i already broke those stupid clips by pushing too hard to the right and i had 2 buy new ones.
Old Nov 17, 2007 | 07:34 PM
azncarbos's Avatar
Kevin wat the other way.
Old Nov 18, 2007 | 01:56 PM
doctordoom's Avatar
Supervillain
sup peter. the other way is just get behind the car. then reach under to the license plate bulb cover/cap, and push right on it. you can see on the cap it will have an arrow to the right and word "remove." it doesn't slide, but it's kinda in there the way a battery is in a game boy. like the battery spring is on the right side in an original game boy. so push it right a little and the left side should pop out of the hatch a little then you can remove the cover.
k sorry i probably made it sound all complicated, but just gently push it right and a little bit outward away from the hatch. don't push too hard because you may snap the plastic clip. if you do, a new one from the dealer is like 9 bucks i think.
Old Nov 18, 2007 | 02:07 PM
azncarbos's Avatar
Thanks mike, I read the original post before you edit. LoL
Old Nov 18, 2007 | 03:37 PM
doctordoom's Avatar
Supervillain
^ hahahhaha i decided i didn't know you well enough to offend you yet. so i changed it.
Old Nov 19, 2007 | 02:16 AM
azncarbos's Avatar
Here are my, just replace them today. I got the Razo Premium white zero
Old Nov 19, 2007 | 05:17 AM
GeorgeC's Avatar
hey where do you guys get these and how much are they?
i'm thinking of going cheap and grabbing these
DealExtreme: $4.50 9-LED Vehicle Signal Lights 2-Pack (12V T15 White)
or
DealExtreme: $3.98 5-LED Vehicle Signal Lights 2-Pack (12V T15 White)
(assuming these are the right size and all)
cheap china stuff
anybody for or against these?
Old Nov 28, 2007 | 08:51 PM
eni9ma's Avatar
WLED-WHP Pure White High Power
If you guys are looking for a clean pure and super bright white you should get these bulbs from SUPER BRIGHT LEDS.
Those coated bulbs(hyper white, etc) all give that blue/white color due to that blue coating they have. I have a pair of these LEDs on my car for my license plate and they look super close to 5000k hid color. They last super long and are damn bright lol.
Don't get the other kind of Led bulbs either, like these:
Those give off that blue/white look and are not so bright compared to the other LED bulb above (WLED-WHP Pure White High Power)
I will try to post picture some time when i get a chance.
P.S. Did I mention that they also light up the ground when there on at night :-)
Old Dec 1, 2007 | 01:52 AM
wrx112's Avatar
**** Goudy. I hate them.
Old Dec 2, 2007 | 04:47 PM
corey415's Avatar
Yeah I'm not sure if I want my license plate more visible to others. Especially if I'm causing mischief...
Old Dec 2, 2007 | 07:10 PM
billmus86's Avatar
My Lips Bigger!
sorry you had to do all that work when it takes like 4 seconds to do it from the outside-- i got the leds from superbrightleds that have to one on the end and 5 or 6 around the edges they are really good not too bright but the perfect color temp
Old Dec 3, 2007 | 04:21 PM
Illmatic07's Avatar
Looks really good, but I had to laugh a little. The first thing I did when I got my fit home was take out those bulbs. I hate those license plate lights. But it looks good on your car.
Gbaby2089
Nov 15, 2009 02:28 PM
scarygoldlion
Nov 16, 2007 01:21 PM
scarygoldlion
Oct 22, 2007 03:52 PM
Rayzel
Aug 27, 2007 03:39 AM
Crawly
May 27, 2007 10:35 PM
