Radiator Cap
Old May 18, 2005 | 02:25 AM
spacetrax@wi.rr.com
Guest
Posts: n/a
Radiator Cap
Have a 97 accord with 187K on it - radiator recently started leaking in
the upper seam on the engine side. A local shop replaced the radiator
- took 2 attempts to get one that would hold fluid - but they did not
replace the cap.
Question - do radiator caps as they age ever hold back too much
pressure - got stuck in some heavy traffic when the radiator started
leaking. Wonder if I should replace the cap.
Thanks
TeGGeR®
Guest
Posts: n/a
Re: Radiator Cap
spacetrax@wi.rr.com wrote in
news:1116271719.746087.172780@o13g2000cwo.googlegr oups.com:
> replace the cap.
Rad caps get old and REFUSE to hold pressure, which will cause boiling.
Absolutely, replace the cap. With OEM if you can get it. It's cheap.
TeGGeR®
www.tegger.com/hondafaq/
Jafir Elkurd
Guest
Posts: n/a
Re: Radiator Cap
The aftermarket radiators from some places fit 90-97... and take the 90-93
cap or the 94-97 cap.... you may have to try both. One's big, one's little.
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns9658A8CD3474tegger@207.14.113.17...
>> replace the cap.
> TeGGeR®
butch burton
Guest
Posts: n/a
Re: Radiator Cap
I understand the spring can get weak and won't hold pressure - can the
opposite happen and subject the system to too much pressure.
Just curious.
Thanks
TeGGeR®
Guest
Posts: n/a
Re: Radiator Cap
"butch burton" <spacetrax@wi.rr.com> wrote in
news:1116282427.434015.193930@g44g2000cwa.googlegr oups.com:
> Just curious.
Guess it could, but personally I've never seen that happen.
TeGGeR®
Old May 18, 2005 | 11:20 PM
butch burton
Guest
Posts: n/a
Re: Radiator Cap
Went back to the garage that replaced the radiator and the guy who owns
the place took a pair of pliers and twisted the drain cock tight and no
leaks. Told me to watch it for leaks. Am buying and carrying a
replacement cock and a gallong of coolant and a gallon of water.
Had this same thing happen on another honda radiator which I replaced -
someone said this is a common problem so watch for leaks around the
drain cock when you have a radiator worked on or replaced.
Fitguy07
Sep 19, 2015 09:23 AM
HondaFitted2007
Oct 9, 2008 01:18 AM
pastafarian
Mar 3, 2008 09:01 PM
R. P.
Sep 4, 2005 06:37 PM
DesignGuy
Jul 19, 2005 11:26 PM
