15x7 +38 with df210???
Old Nov 23, 2007 | 11:05 PM
japspeed1's Avatar
Question 15x7 +38 with df210???
i posted this in suspension and in wheel forums because its about both, would 15x7 +38 with factory tires work with tanabe df210?
Old Nov 23, 2007 | 11:35 PM
cHuNsTa's Avatar
ur gonna rub on big dips most likely and taking ur car hard on turns.
Old Nov 24, 2007 | 08:16 AM
japspeed1's Avatar
yeah thats what somebdy else said but is it the low offset of the wheels or the springs because i dont think the df210 rubs on factory sport wheel and tire right, so must be the wheel. the reason is i want two sets of wheels cause i bored with wheels quick,that way i can swap them out evey month or so, my first choice shouldnt be a problem almost the same as you had, konigs helium black red but in 15, my second choice is the drag dr20, i could only find in +38, i think the konigs are +40, so just 2mm makes that much difference, maybe a different size tire on the drags would help like a 50 instead of 55?
Old Nov 24, 2007 | 10:35 AM
jits14's Avatar
I have df210s and I also had a set of 16x7 +38 offset. They never once rubbed even on dips. It all depends on the type of tire you pick, I had a flat performance tread.
Old Nov 24, 2007 | 02:17 PM
cHuNsTa's Avatar
u might be ok with a 195 50 15 with the offset. my konigs rubbed cuz i had 205 45 16. its not bad but when u hit a dip it rubs on the little screw on the top of ur fender wall. its just annoying for me.
Socialvegetable
Jul 29, 2011 03:14 AM
evo9tofit?
Jan 2, 2010 11:15 AM
DMC
Aug 5, 2008 10:37 PM
Kuturagi
Dec 11, 2007 08:50 AM
aallbbeerrtttttt
Nov 19, 2007 10:29 AM
