2000 Honda Accord EGR valve
Old May 18, 2005 | 02:25 AM
Darellbrownnose
Guest
Posts: n/a
I had the EGR valve on my 2000 Honda Accord 4cyl
changed. I am now told the ports need cleaning. The check engine light
is on and keeping me from getting an inspection. Can I clean the ports
myself if so How?? Thanks
Professor
Guest
Posts: n/a
Re: 2000 Honda Accord EGR valve
The EGR ports can get blocked after some time by hard black deposits.
The only way to clean the involved ports is to remove the EGR valve and
start scraping. A solvent might also be utilized. Depending on how bad
the deposits are... certain intake components may have to be removed.
But before you go through all that... you better run the error code and
see what it says...
Professor
www.telstar-electronics.com
Darellbrownnose
Guest
Posts: n/a
On 17 May 2005 10:44:37 -0700, "Professor"
>see what it says...
>Professor
thanks professor i'll gingerly attempt the scraping.
Professor
Guest
Posts: n/a
You might want to fire up the vacuum cleaner and hold the nozzle near
as you scrape... to keep the black crap from falling inside the port.
Professor
Steve Bigelow
Guest
Posts: n/a
"Darellbrownnose" <phoenixone@kosby.net> wrote in message
news:sp9k81tpebc2cpgonp82106g05tn0opquj@4ax.com...
The plugs come out with a drill and a slidehammer. Clean them with fine
drill bits and spray solvents, and pop in new plugs.
Old May 18, 2005 | 11:20 PM
Woody
Guest
Posts: n/a
Check with your dealer as there is a tsl on putting a liner in the port
because of the problem on the V6. Many Odyssey owners had it done for free.
See www.odyclub.com. Before tearing into the engine check with the dealer.
You may also want to do some research on the problem on the net....
codenamezero
Sep 21, 2016 08:23 AM
Mynodha
Jul 17, 2014 01:25 AM
Lamak
Mar 15, 2009 03:24 AM
mikepier@optonline.net
Oct 7, 2005 08:30 AM
hisame2332
Sep 6, 2005 02:53 PM
