Honda CR-V brake failure
Old May 22, 2005 | 10:16 PM
kodogo
Guest
Posts: n/a
I was recently involved in a low-impact collision while driving a 2004
Honda CR-V. I hit the back of another car at round 25kph, denting the
radiator, and immediately after the collision my brakes failed, and I
had to bring the car to a halt using the parking brake. Shortly
afterwards, two independent witnesses - one an experienced tow truck
driver - verified that the brake pedal went straight to the floor with
no resistance. However, after a few days at the body shop, it seems as
if the brakes are working normally. Does anyone have any ideas how this
might have happened? I don't feel safe driving the car in future unless
I know that the problem has been fixed - does anyone have any
suggestions what might have happened, and how to approach Honda about
this?
motsco_ _
Guest
Posts: n/a
Re: Honda CR-V brake failure
> this?
Why not ask the body shop what steps they took to fix your brakes? It
might even be mentioned on the work order.
'Curly'
Debbie Willis
Guest
Posts: n/a
The body shop have taken no steps to fix the brakes. The worrying thing is
that they definitely failed, have possibly come right with no intervention,
and I'd like to know how this could happen, and how I can be sure it won't
happen again.
> 'Curly'
motsco_ _
Guest
Posts: n/a
> happen again.
>>'Curly'
Is the reservoir full enough now? (See manual if you're not sure). Does
the 'BRAKES' lamp pass the test every time you go to start the car?
Maybe you should sign in, and post your question at hondasuv.com .
Somebody there may have seen the same problem.
'Curly'
Old May 28, 2005 | 04:41 PM
Mike
Guest
Posts: n/a
Just a thought...could be ...
If you hit the other car and the engine stopped the power brake function
would not function. The brake pedal would collapse and go down by several
inches. The brakes would still work but you would have to press the pedal
very hard. When the engine is restarted the power brake would return to
normal. I assume that after bring the car to a stop it was towed to the
shop. Did the pedal actually go to the floor or did it just drop by a couple
of inches? Next time you turn of the ignition try doing it with your foot on
the brake pedal. As the engine dies the pedal will sink.
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:428DC797.1030501@interbaun.com...
>> is
>> intervention,
>> won't
>> happen again.
>>>'Curly'
> the 'BRAKES' lamp pass the test every time you go to start the car? Maybe
> you should sign in, and post your question at hondasuv.com . Somebody
> 'Curly'
Thismightnotfit
Jun 2, 2012 05:05 PM
sweatmachine
Apr 3, 2010 11:57 PM
Chairman Kaga
Sep 14, 2009 02:29 PM
thomas.jacobs@dva.state.wi.us
Oct 6, 2005 09:30 AM
DavidB
May 4, 2005 11:16 AM
