planning to uy & Install B&M #70255 SuperCooler
Old Nov 29, 2007 | 04:24 PM
sanosuque's Avatar
I'm interesting in the Turbo for my Honda fit A/T.jejjee
I got a question...
I'm interesting in Buy the cooler for the tranny
B&M #70255 SuperCooler Automatic Transmission Cooler
eBay Motors: B&M #70255 SuperCooler Automatic Transmission Cooler (item 300145644931 end time Nov-25-07 08:00:44 PST)
This type of cooler is easy to install? It can void the warranty?
Its necessary to Make a hole into the tranny for the cable or something? thanks
Old Dec 10, 2007 | 02:15 PM
Kostas's Avatar
I got a question...
I do not think that is necessary.
Fit transmission has already cooler system for the oem engine radiator.
Old Dec 10, 2007 | 04:31 PM
sanosuque's Avatar
so..it can support a turbo with the factory cooler? interesting.
Old Dec 10, 2007 | 10:37 PM
Jsmitty's Avatar
Just get metal tubbing with the correct fitting, correct line size bent to match the factory one. It should run to a rubber hose then to metal tubing to the trans. Same method for the coolant lines from the radiator. I'm not exactly certain on this car, because I have a manual trans. Just going from general knowledge. Some people just use a small electric fan on the factory cooler. Just be careful cause it can going from a small idea to a real big mess. Research is key.
Old Dec 10, 2007 | 11:00 PM
claymore's Avatar
There is a giant post about oil coolers on the Jazz/Fit try a search and you will find the answer
Old Dec 11, 2007 | 12:47 PM
kimo's Avatar
Buy Hayden is cheaper.
Paul56
Jul 27, 2011 03:20 AM
GatorFit24
May 1, 2011 01:05 AM
skeezy
Feb 17, 2011 07:18 AM
sansar
Apr 12, 2007 11:56 PM
