Testing alternator.
Old May 22, 2005 | 10:16 PM
Matt Ion
Guest
Posts: n/a
Testing alternator.
Bought an '87 Accord hatchback recently (2.0l, 2bbl, 5spd)... owner was
selling it because the alternator "didn't work". Seemed to me that it
worked, but not 100%. In any case, I swapped in the alternator from my
identical '87 sedan that had just bit the dust, and all was happy until
a couple nights ago: charge light flickering, dashlights dim, except
when revving high. Typical indication of bad brushes. Figured I was
doing okay trying to get home when suddenly the charge light came on
solid and wouldn't go out for anything. JUST made it home, engine
sputtering every time I hit the brakes.
So today I pulled apart the original alt. and checked it out: diodes all
test fine, field windings seem okay, no opens or shorts anywhere.
Brushes weren't too badly worn, so not really sure what was wrong with it.
Got the replacement alt. out of the car (finally - some Japanese SOB
needs a serious bitchslapping over the layout of that engine) an opened
it up... brushes were REALLY worn, but still making contact - barely.
Diodes and windings checked okay as well.
Now the only thing I can't test is the voltage regulator. Or can I?
With a stanard multimeter, that is, since I don't have a nice
super-duper alternator/starter bench tester sitting on my kitchen
table...?
I took a few readings across various terminals of both regulators, DMM
set to Diode Check, and got several readings that differed between the
two... for example, testing from "terminal A" (named arbitrarily for the
sake of argument) to terminals B and C on one regulator showed infinite
resistance, but on the other, they showed about 1200Mohms aa 1800Mohms,
respectively. Reversing the leads, the first regulator showed 1200 and
1500 (B-to-A and C-to-A), but the other, I got 1500M and infinite,
respectively. Obviously I don't know which one is "right" reading, and
it's not enough to make an intelligent diagnosis.
So... does anyone know of any way I can test the regulator? Or better
yet, know how I can hook up the alternator on the bench (ie. what goes
to what connections) and test it there, maybe spin it up with my
cordless drill?
TIA...
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0520-4, 05/20/2005
Tested on: 5/21/2005 6:49:08 PM
avast! - copyright (c) 1988-2005 ALWIL Software.
http://www.avast.com
Michael Pardee
Guest
Posts: n/a
Re: Testing alternator.
"Matt Ion" <soundy@moltenimage.com> wrote in message
news:HyRje.1430261$Xk.1354855@pd7tw3no...
> identical '87 sedan that had just bit the dust, and all was happy until a
> couple nights ago: charge light flickering, dashlights dim, except when
> revving high. Typical indication of bad brushes. Figured I was doing
> okay trying to get home when suddenly the charge light came on solid and
> wouldn't go out for anything. JUST made it home, engine sputtering every
> test fine, field windings seem okay, no opens or shorts anywhere. Brushes
> Got the replacement alt. out of the car (finally - some Japanese SOB needs
> a serious bitchslapping over the layout of that engine) an opened it up...
> brushes were REALLY worn, but still making contact - barely. Diodes and
> Now the only thing I can't test is the voltage regulator. Or can I? With
> a stanard multimeter, that is, since I don't have a nice super-duper
> alternator/starter bench tester sitting on my kitchen table...?
> I took a few readings across various terminals of both regulators, DMM set
> to Diode Check, and got several readings that differed between the two...
> for example, testing from "terminal A" (named arbitrarily for the sake of
> yet, know how I can hook up the alternator on the bench (ie. what goes to
> what connections) and test it there, maybe spin it up with my cordless
> drill?
> TIA...
There isn't any great way to test it on the bench with common tools - it is
a lot easier to test it in service with a DMM. However, most major auto
parts stores have a test jig, where they can spin the alternator with an
electric motor and measure the output under various loads... and they will
do it for free.
Mike
Old May 23, 2005 | 05:01 PM
Matt Ion
Guest
Posts: n/a
>>drill?
>>TIA...
> do it for free.
There must be some way to test the regulator module itself - supply
juice to the inputs, measure the outputs? As I say, all the other
components are fairly "testable" on their own and seem to be fine...
Tested on: 5/22/2005 7:26:32 PM
Michael Pardee
Guest
Posts: n/a
news:Pbbke.1450703$8l.104325@pd7tw1no...
>>>drill?
>>>TIA...
>> is a lot easier to test it in service with a DMM. However, most major
>> auto parts stores have a test jig, where they can spin the alternator
>> with an electric motor and measure the output under various loads... and
>> they will do it for free.
> There must be some way to test the regulator module itself - supply juice
> to the inputs, measure the outputs? As I say, all the other components
Maybe, but I'm not sure. Some old voltage regulators used analog drivers,
but I think all of them now are switch mode, pulsing the inductance of the
field. You could connect the regulator to the alternator and measure current
drain as you turned the input voltage up - the current should drop rapidly
as you exceed the regulator point (somewhere around 14 volts).
Mike
Matt Ion
Guest
Posts: n/a
>>>>drill?
>>>>TIA...
Cool, except it still has to be in the car for that, which in itself is
a nightmare, and at that point is wholly inaccessible :) Assuming one
determines which connections are which on the thing, too.
I guess that's what I'm really hoping, is to find the pinouts for the
module; given those, I may be able to at least tell, without putting it
all back together and into the car, whether either of the two regulators
I have are *obviously* faulty.
Recall that the original alternator in the car worked intermittantly,
and upon disassembly and testing, the brushes seem sufficient and
everything else I CAN test (windings, diodes) seems good, so that leaves
the regulator as "questionable".
The behaviour of the second one worries me a little, the way it was
doing the typical worn-brush thing for only a little while before
packing it in completely: again, the brushes are obviously gone, and
everything else tests fine, and I don't want to put it all back together
and into the car only to discover the regulator is pooched. A simple
works/doesn't-works test is all I'm looking for.
Virus Database (VPS): 0521-0, 05/23/2005
Tested on: 5/23/2005 8:57:06 AM
Old May 28, 2005 | 04:41 PM
twillmon@cybermesa.net
Guest
Posts: n/a
On 2005-05-23 psOdnW7wK-4q-AzfRVn-qw@sedona.net said:
>Newsgroups: rec.autos.makers.honda,alt.autos.honda
>>>>>owner was selling it because the alternator "didn't work".
>>>>>Seemed to me that it worked, but not 100%. In any case, I
>>>>>swapped in the alternator from my identical '87 sedan that had
>>>>>just bit the dust, and all was happy until a couple nights ago:
>>>>>charge light flickering, dashlights dim, except when revving
>engine sputtering every time I hit the brakes. >>>>
>>>>>diodes all test fine, field windings seem okay, no opens or
>>>>>shorts anywhere. Brushes weren't too badly worn, so not really
>sure what was wrong with it. >>>>
>>>>>Japanese SOB needs a serious bitchslapping over the layout of
>>>>>that engine) an opened it up... brushes were REALLY worn, but
>>>>>still making contact - barely. Diodes and windings checked okay
>as well. >>>>
>>>>>can I? With a stanard multimeter, that is, since I don't have a
>>>>>nice super-duper alternator/starter bench tester sitting on my
>kitchen table...? >>>>
>>>>>regulators, DMM set to Diode Check, and got several readings
>>>>>that differed between the two... for example, testing from
>>>>>"terminal A" (named arbitrarily for the sake of argument) to
>>>>>terminals B and C on one regulator showed infinite resistance,
>>>>>1200 and 1500 (B-to-A and C-to-A), but the other, I got 1500M
>>>>>and infinite, respectively. Obviously I don't know which one
>is "right" reading, and it's not enough to make an intelligent
>>>>>diagnosis. >>>> So... does anyone know of any way I can test
>>>>>the regulator? Or better yet, know how I can hook up the
>>>>>alternator on the bench (ie. what goes to what connections) and
>>>>>test it there, maybe spin it up with my cordless drill?
>>>>>TIA...
>>>>tools - it is a lot easier to test it in service with a DMM.
>>>>However, most major auto parts stores have a test jig, where
>>>>they can spin the alternator with an electric motor and measure
>>>>the output under various loads... and they will do it for free.
>>>supply juice to the inputs, measure the outputs? As I say, all
>>>the other components are fairly "testable" on their own and seem
>to be fine... >>
>>drivers, but I think all of them now are switch mode, pulsing the
>>inductance of the field. You could connect the regulator to the
>>alternator and measure current drain as you turned the input
>>voltage up - the current should drop rapidly as you exceed the
>itself is a nightmare, and at that point is wholly inaccessible :)
>Assuming one determines which connections are which on the thing,
>too.
>the module; given those, I may be able to at least tell, without
>putting it all back together and into the car, whether either of
>the two regulators I have are *obviously* faulty.
>intermittantly, and upon disassembly and testing, the brushes seem
>sufficient and everything else I CAN test (windings, diodes) seems
>good, so that leaves the regulator as "questionable".
>together and into the car only to discover the regulator is pooched.
>A simple works/doesn't-works test is all I'm looking for.
Is there anything wrong with taking your alternator to a parts store
for testing on their machine? Next town over has a Checker parts
store with at least one real competent guy who would test yours.
Tom Willmon
near Mountainair, (mid) New Mexico, USA
Sure it's funny! Now beam my clothes down Scotty!
Net-Tamer V 1.12.0 - Registered
Matt Ion
Guest
Posts: n/a
Did that. Tested fine. Put it back in the car. Now it works
intermittantly. It'll run 13V at idle, up to 14.1 at speed, but if I
start turning stuff on (lights, blower) it'll drop below 12V; ie. not
charging at all. Turning everything off again, it takes upwards of 30s
of revving to start charging again.
I'm wondering if a brush isn't in quite right, as there's a 'ticking'
sound coming from it now that changes with engine speed.
Tested on: 5/23/2005 8:07:49 PM
Jason
Guest
Posts: n/a
In article <yUwke.1462539$8l.864164@pd7tw1no>, Matt Ion
Unless you know how to rebuilt it yourself, I advise you to buy a new
alternator. Another option is to visit a car junk yard. If the manager or
owner is on a database of thousands of junk yard, he can order you one
even if he does not have one in stock. The owner or manager may even
provide a warranty for it in case it does not work. I once found a wrecked
car just like the one I owned at that time and got lots of parts off of it
for almost nothing.
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
maldonw613
Feb 4, 2024 07:11 PM
Kevin Evans
Dec 13, 2018 11:01 PM
JazzyNL
Dec 13, 2017 03:06 AM
craigquakertown
Jul 3, 2017 02:58 PM
SevereService
Mar 26, 2014 06:00 AM
