Sponsored by:
Sponsored by: CARiD
Question: White Smoke during Engine Warm Up
Old Dec 18, 2007 | 10:07 AM
be2kz's Avatar
Question Question: White Smoke during Engine Warm Up
Hi..
I own 2005 Honda Jazz mileage 28.000 KM. In the morning during engine warm up, white smoke comes from the exhaust pipe and soon dissapear several minutes after reaching optimum temp. (engine temp. light goes off). The white smoke smell rather like gasoline. Is this normal? Can anyone explain what causing this to happen?
Thank you...
Old Dec 18, 2007 | 11:22 AM
manxman's Avatar
It is steam from condensed moisture that forms as the metal of your exhaust system cools down in cold, damp weather.
Old Dec 18, 2007 | 12:27 PM
kndlewis's Avatar
Burnt gasoline is usually seen as black/grey smoke. Oil burning would be seen as white smoke.
I tend to agree with manxman. But if you have concerns, keep an eye on your oil level.
Old Dec 18, 2007 | 12:33 PM
manxman's Avatar
Have to disagree with your here- Oil= blue smoke, fuel= black smoke, white= not smoke but steam. Has been that way for 100 years, but I am willing to grant that catalytic converters may have the effect of minor changes on these visual symptoms. Regardless, white is steam.
phil_qc's Avatar
oil = blue
gaz = black
prestone = white
condensation = what you got... white
Old Dec 18, 2007 | 12:47 PM
manxman's Avatar
Originally Posted by phil_qc
oil = blue
gaz = black
prestone = white
Looks like I have a French Canadian twin!
Old Dec 18, 2007 | 12:59 PM
doctordoom's Avatar
Supervillain
yup, don't worry unless the smoke is blue or black. and it goes away after warm up too so you're fine.
Old Dec 18, 2007 | 04:38 PM
percy's Avatar
It's probably water vapor, since water and carbon dioxide are by far the two biggest byproducts of combustion. It smells like gas simply because the cat hasn't warmed up yet and therefore isn't working at it's ideal temperature. So what you're probably seeing is simply steam, as noted above. If it really is white "smoke", and is always there, it would suggest that you're buring coolant because of a head gasket or other problem, but that is highly unlikely based on what you've told us.
Old Dec 18, 2007 | 07:24 PM
TOOL's Avatar
If you havent noticed every car does this in the winter. its 100% normal. I love the way it looks coming out of my dual pipe megan exhaust lol. I know im weird.
Tyler
Old Dec 19, 2007 | 02:44 AM
BlackCobra's Avatar
Tyler
PLUS 1 on that
Old Jan 14, 2008 | 12:13 AM
saiko's Avatar
Avid FitFreak Poster
Just water buddy
Old Feb 21, 2008 | 02:48 PM
07fitsport's Avatar
water/steam condensation from heat engine to the cold..should be normal
BLXFITTY
Sep 27, 2014 09:32 AM
chazmr
Jul 24, 2014 10:18 PM
initialRC
Sep 28, 2013 08:14 PM
santa
Sep 22, 2009 09:50 AM
corih
Nov 18, 2006 08:37 PM
