1999 Odyssey water under carpet...
Old May 28, 2005 | 04:41 PM
Yenski News
Guest
Posts: n/a
In 2004, I installed a DVD system and when removing the seats and carpet (to
hide the wires) noticed that the foam backing of the carpet on the front
passenger floor (near the door) was saturated with water. So, I removed the
entire carpet to dry. Yesterday, I was vacuuming the vehicle and thought I
would inspect. I lifted off the kick plat e moulding to lift up the carpet
and sure enough it is wet again.
Anyone know where the water is coming from? I'm guessing the A/C or heater
core, but cannot find the source of the leak. I have searched the net and
found a link that the pillar was leaking water, but this may not be the
case.
Thanks
Woody
Guest
Posts: n/a
Re: 1999 Odyssey water under carpet...
It could be condensation from the evaporator. If so the drain tube is
blocked. This usually leads to mold and smell coming from the air vents.
Find the drain tube and clear it. It should be near and below where the A/C
hoses go thru the firewall....
"Yenski News" <yenski-ebay2@cox.net> wrote in message
news:iqqle.35551$aB.16658@lakeread03...
> (to hide the wires) noticed that the foam backing of the carpet on the
> front passenger floor (near the door) was saturated with water. So, I
> removed the entire carpet to dry. Yesterday, I was vacuuming the vehicle
> and thought I would inspect. I lifted off the kick plat e moulding to
> lift up the carpet and sure enough it is wet again.
> heater core, but cannot find the source of the leak. I have searched the
> net and found a link that the pillar was leaking water, but this may not
> be the case.
> Thanks
hiptech@gmail.com
Guest
Posts: n/a
> case.
> Thanks
hiptech@gmail.com
Guest
Posts: n/a
As previously stated, my first guess would be the evaporator condensor.
There are 2 other potential areas. You never mentioned if you have a
sunroof? Even though the '99 - '04 Odys didn't offer a factory
sunroof, many dealers were installing aftermarket units. If you have
one, the drain tubes could be clogged there as well.
The other area that comes to mind is the windshield. Here again, if
you had one recently replaced and it wasn't properly installed this
would most definitely be a trouble spot.
Since you don't mention if you are the orignal owner, a windshield
could have replaced before you purchased the van. So you may want to
have it checked?
Good luck
Old Jun 3, 2005 | 01:06 AM
Professor
Guest
Posts: n/a
Absolutely... the problem is that many times after clearing the
drain... it will become blocked again with a muddy type substance that
is the result of decomposing leaves and seeds that have made their way
throough the ventilation intake over the years. Actually, the one way I
have stopped the repeated clogging is to actually fill the plenum up
with water throught that same drain, in an attempt to rinse it out
good. The only other way is to take the plenum apart to clean as a last
resort.
Professor
www.telstar-electronics.com
KWW
Guest
Posts: n/a
Any diagrams of this hose and its location?
KWW
"Woody" <TheDuck@pond.net> wrote in message
news:rctle.1939$2u1.1143@newssvr19.news.prodigy.co m...
> A/C hoses go thru the firewall....
>> be the case.
>> Thanks
KWW
Guest
Posts: n/a
Where does this hose travel in the body? Where can I get diagrams?
KWW
<hiptech@gmail.com> wrote in message
news:1117246150.681510.204760@o13g2000cwo.googlegr oups.com...
> have it checked?
> Good luck
Professor
Guest
Posts: n/a
This drain is normally located on the passenger side. You must get
under the vehicle and look from the outside to locate. When you do find
it... run something through it and get ready for a shower... LOL
Be careful when poking through the blockage... the evaporater core is
close by inside the plenum... and a gorilla touch could get you a
puncture in it. I suggest using something wood instead of metal to poke
with.
Professor
> KWW
> > have it checked?
> > Good luck
KWW
Guest
Posts: n/a
Thanks. It turns out the AC drain is fairly clear.
I suspect that the liquid right around the driver's side for the rear seat
may have been from the rear window washer. I will have to see if the line
is loose somewhere.
The driver's floor.... don't know... but I never have done anything to the
sunroof drain. For that matter I don't know where to lube the sunroof
itself... but that's another thread... I guess.,
KWW
"Professor" <briangriffey@sbcglobal.net> wrote in message
news:1117561073.782482.321700@g47g2000cwa.googlegr oups.com...
> with.
> Professor
>> KWW
>> > have it checked?
>> > Good luck
benjamingrantdu
Jan 12, 2012 07:14 PM
veteran13
Nov 1, 2009 04:37 PM
Luichenwai
Nov 11, 2008 10:32 AM
kinosh
May 29, 2008 01:25 PM
sweetc_66
Aug 18, 2005 12:30 AM
