cant find TPS signal wire
Old Dec 30, 2007 | 05:01 PM
quangalang's Avatar
does anyone know where the tps signal wire is?? or what color?
Old Dec 30, 2007 | 11:06 PM
claymore's Avatar
There should be three wires from TPS, yellow/blue, red/black and green/ black. The yellow/blue and green/black also connect to other sensors but the red /black goes directly to the ECU. Take your pick
Old Dec 31, 2007 | 12:27 AM
quangalang's Avatar
i know most hondas have red/black for TPS signal wire but when i look on the diagram(above). it says red/black is "(ATPN)" i dont even know what it stands for
Old Jan 3, 2008 | 05:09 PM
quangalang's Avatar
bump bump bump
Old Jan 3, 2008 | 11:42 PM
claymore's Avatar
Check this diagram under OBD-2a Connector "D" position #1 it's for mainly Civics but most hondas are the same and it has the proper color red/black.
Honda ECU Pin outs - HondaTech Australia Forums
Old Jan 4, 2008 | 12:49 AM
downest's Avatar
If that's out of your Fit Helms manual, you should be able to just look through the wiring diagram section and trace it back. I can look tomorrow for you when I get into the shop.
Old Jan 4, 2008 | 09:42 PM
quangalang's Avatar
remember that the NA fits have DBW and i can't find the tps sensor on the throttle body, it's somehow tied into the DBW system.
the diagram i provided above is it for the the 2007 fit, the red/black wire is for (ATPN)
Old Jan 7, 2008 | 05:13 PM
explosivpotato's Avatar
behind the throttle body, there's a plug with six wires. The top wire is red with a black stripe. Thats the one. I just did a nitrous install and this is the wire I tapped into.
Old Jan 10, 2008 | 12:57 PM
bigtymer8700's Avatar
man i could kiss u right now potatoe ive been looking for that wire for a while. that little plasic cover behind the TB kept hiding those wires i finally got behind there and found it thanks
Old Jan 14, 2008 | 01:28 PM
alf74's Avatar
It isn't difficult to find it with a multimeter. Its voltage is 0-5v....
Old Jan 15, 2008 | 09:56 AM
alf74's Avatar
In my Honda Jazz it's the yellow wire and has 5-0v
The red wire has 12-0v
Old Jan 19, 2008 | 06:38 AM
quangalang's Avatar
thanks everyone for helping out. rep to potato for confirming that
Xitomatl
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Aug 20, 2019 01:46 PM
Pjbrady
Fit I.C.E.
Mar 14, 2015 01:24 PM
xenomorph
Feb 14, 2011 04:10 AM
tdesi420
Feb 15, 2009 10:36 PM
bigtymer8700
35
Mar 23, 2008 12:05 AM
