Re: Any recommendation for aftermarket headlamp bulbs for 94-97 Accord
Old Jun 4, 2005 | 11:09 PM
jim beam
Guest
Posts: n/a
techman41973@yahoo.com wrote:
> I need to replace the stock bulbs on my Accord and found them a bit dim
> for low beams. I do plan to re-aim to see if I get an improvement. Can
> anyone recommend a good set of bulbs for the GEN-4 94-97 accord that
> were found to give better results than the stock bulbs? Thanks
bulbs dim with time. just buy ordinary new ones - they'll be brighter.
and cheaper.
y_p_w
Guest
Posts: n/a
> and cheaper.
Not only that, but the wiring degrades with time and service.
However - I'd recommend Sylvania XtraVision. I think the Accord uses
9006. XtraVision will be less than $20 at WalMart and will produce
more light, although it doesn't aim for that perception that it's
similar to HID.
Whatever you do - don't use Sylvania Silverstar, which is a horrible
waste of money and which only gives an "optical illusion" of better
performance. They not only cost 2-3 times as much, but they have a
rated life of 150 hours (9006), compared to 850 for the XtraVision
and 1200 for standard Sylvania 9006.
y_p_w
Guest
Posts: n/a
>> brighter. and cheaper.
> similar to HID.
Clarification - less than $20 a pair for 9006 at Wal-Mart.
Morair
May 9, 2012 08:26 AM
idlingmike
Mar 22, 2010 01:45 PM
mnapuran
Mar 28, 2008 02:53 AM
Beretta
Mar 10, 2008 07:36 PM
pedaler
Nov 28, 2006 11:51 AM
