Jazz Window Winder Removal
Old Jan 10, 2008 | 07:49 AM
Sally's Avatar
Hi,
I need to take the rear door cards off. Anyone got any ideas on how the rear manual window winders on a 2002 Jazz come off?
Some manuals talk of a clip on the inside of the handle that you pull off with a hook and then remove the winder. Mine doesn't appear to have anything like this. Guessing it might be different on the earlier models>
Thanks in advance,
Sally.
Old Jan 10, 2008 | 10:30 AM
claymore's Avatar
You have to separate the plastic washer away from seating against the handle. Push/ separate the plastic and look down at the center of the shaft and you will see the clip or what looks like a thin silver ring that is the backside of the clip just move further around the handle and pull out with thin pliers or bent up metal hook.
BuddaOne
Nov 25, 2018 04:08 AM
larshnordli
Jul 25, 2018 09:31 AM
Projectm6
Jan 5, 2018 01:58 AM
Chris Nicola
Feb 23, 2012 09:07 AM
Matt888
Dec 4, 2009 01:03 PM
