1990 Accord Distributor
Old Jun 13, 2005 | 03:26 PM
lincw@yahoo.com
Guest
Posts: n/a
Hi all,
I have a 1990 Honda Accord EX that does not start. I can turn the
engine but it won't start.
I had it on a car ramp to change oil and maintenance. When I was done
I started the car, while on the ramps, and it died after about 2
seconds. Now my car had done this before, I would take out the key and
wait for about a minute and start the car again. This time it wouldn't
start. I found out I had left the number 1 spark plug wire off, DOH!
I plugged the wire back in, it still wouldn't start. Could this have
caused some damaged?
My friend came over to help check it out. He stuck a screwdriver in
the number 1 plug wire and held it near a ground plug. I cranked the
engine and there was no spark. He says its the distributor.
I'm not sure how to check it properly. But could it be something else
not working, main relay or alternator, thus having the affect of the
distributor appearing to be damaged?
Any thoughts/comments would be greatly appreciated!!!
SoCalMike
Guest
Posts: n/a
Re: 1990 Accord Distributor
id pop the cap off and at least check the cap/rotor, and look for
"bearing dust". have him crank it and make sure the rotor turns.
new cap/rotor? still doesnt work? id go with the main relay.
lincw
Guest
Posts: n/a
We cranked the engine and the rotor did spin....
Its not a new cap or rotor. I had not done any maintenance with the
distributor at all. Is it correct to say that if the main relay is
bad, it would give the appearance of the distributor not working?
Thanks....
jim beam
Guest
Posts: n/a
> Hi all,
check the coil. if that sparks ok when energized, look at the igniter
circuitry. i know the accord's not the same as the civic which is bad
in this area, but check it anyway.
SoCalMike
Guest
Posts: n/a
after 12 years, its probably worth a new OEM cap, rotor, and wires.
> Thanks....
lincw
Guest
Posts: n/a
I tested the coil and when energized it does output 12 volts
Would that prove its not the igniter or coil that is faulty?
When I crank, the rotor does spin. But no spark at the end of the
wire. Would this absolutely point to the cap and wires as the
culprits?
Someone mentioned maybe the timing belt broke?
Thanks....
SoCalMike
Guest
Posts: n/a
> culprits?
cap/wires/rotor. worth it, after 15 miles. OEM all the way, even if you
have to buy online.
is it ALL plugs not getting spark, or just the one?
rotor wouldnt spin.
> Thanks....
TeGGeR®
Guest
Posts: n/a
"lincw" <lincw@yahoo.com> wrote in
news:1118525985.233006.123820@f14g2000cwb.googlegr oups.com:
Leaving the #1 spark plug wire off has killed the coil.
A partial path to ground has been established through the coil body, so it
is leaking the high-tension current off before it can reach the plugs. Your
12V test voltage tells you nothing.
You have no choice but to replace it.
http://www.tegger.com/hondafaq/start...s.html#badcoil
TeGGeR®
Old Jun 22, 2005 | 01:43 PM
lincw
Guest
Posts: n/a
Cool link, thanks. I ended up getting an off duty mechanic to come
over and he tested the coil somehow with a multimeter. He said the
resistance was kind of low and that the coil needed to be replaced.
I asked him if running the car without the #1 spark plug wire on the
spark plug would kill it, he said not likely.
He change it out and the car startup just fine.
>From my perspective, that is the only thing that I could think that I
did that would've caused the problem. Everyone I talked to said it not
likely to have caused the problem.
Your FAQ makes sense to me and at least provides logic to the problem.
I spent a lot of time looking for the main relay too, thinking that
might be the problem.
FYI, for those reading this in the future, it is located to the left of
the steering column. If you go underneath the dash and look up you
will not see it. You have to remove this 4"x4"x1" silver metallic
box, cruise control. Then you will see the main relay.
Thanks to all who replied.....
Old Oct 28, 2011 | 02:44 AM
ktyler's Avatar
> culprits?
have to buy online.
rotor wouldnt spin.
> Thanks....
A very late in time thread but guess this would be the thing I need to solve the issue. Apologize for the disturbance but you can still join me if you are still here. Here’s the story. I've got a 1993 Civic CX Hatch, auto with 280k on it that's having a bit of a distributor issue. Yesterday the car started and would shut off after about 2 seconds. I have also do the change oil but the crankshaft is not doing well. So what I did was to check the pump and I could figured out it is in good condition. Is this a possible problem on the distributor….?
__________________________________________________ _____
1993 Honda del sol Si |Useful threads: Honda distributor|Honda Civic
CarDomain Page |Not yet undergone mods and replacement|
Carl Gerhold
Dec 13, 2020 11:10 PM
large member
Sep 18, 2005 02:42 AM
Goomanjbs
Jul 11, 2005 05:50 PM
caroline_t
May 28, 2005 04:41 PM
stevie
May 6, 2005 11:47 AM
