Oil in spark plugs
Old Jun 13, 2005 | 03:26 PM
bigrob4201
Guest
Posts: n/a
Oil in spark plugs
in my fiancees 93 accord there is oil in the spark plugs. We had a flood
here last night and when i was going to work i got stuck in some high
water. It killed the engine but i got it restarted and got back home well
the engine died 2 or 3 more times and then after i got home it wouldnt
restart. Is that because of oil or the water? Did the water cause the
oil? any help woould be greatly appreciated. Thanks
Woody
Guest
Posts: n/a
Re: Oil in spark plugs
Did you check for water in the oil? Did you check for water in the intake?
The oil in the plugs is coming from somewhere. Was it there before you tried
using it for a boat?
"bigrob4201" <robert_o38@hotmail.com> wrote in message
news:7a51cab93c17f07d07dc60e74ed14322@localhost.ta lkaboutautos.com...
bigrob4201
Guest
Posts: n/a
I dont know if the oil was there before or not. It looked like there was
some baked onto one of the wires, where it connects to the spark plug. I
got the car to start today, but it just died again. Her moms taking it to
a mechanic tomorrow. But thanks for the help
Old Jun 27, 2005 | 08:22 AM
Dan0845
Guest
Posts: n/a
I have the same problem with my 93 Accord. I was noticing a very slight
skip at idle and since I had not changed the plugs in a while, I checked
them...there was oil standing in all four plug wells. Oil is apparently
not in the engine...I have no burnage or any smoke, but one of the plugs
had burned-on oil as you described. I do have slight "skipage" at various
speeds...maybe this is another problem...AT related, I hope not!! Maybe
you can tell me what you found out or someone else may offer some help.
Thanks,
Dan
PS..I was never in a flood..haha!
Steve Bigelow
Guest
Posts: n/a
"Dan0845" <danprev@hotmail.com> wrote in message
news:b3a0bec12ea84609d5351a0fba9c55d9@localhost.ta lkaboutautos.com...
> Thanks,
> Dan
EGR ports clogged.
motsco_ _
Guest
Posts: n/a
> Thanks,
> Dan
There's rubbar seals about 3/4 way down inside the holes in the cover
where the plugs go. They keep the oil INSIDE the valve cover. When they
get OLD, they start to leak unburnt (liquid) oil into the plug's domain.
On some engines, you just remove valve cover and replace them. On
others, the camshafts have to come out, i think.
Search this group, or google.com to find the cure. Try tegger's faq:
http://www.tegger.com/hondafaq/
Also, change your ATF with Honda Z1, and do it again a week later if you
have any doubts whether it's been done.. always quote your mileage.
'Curly'
Dan0845
Guest
Posts: n/a
Steve,
I hate to sound stupid, but what are EGR ports and how might I deal with
this myself or is an expert required? Is this a more obvious cause than
worn out seals or valve cover gasket...and I assume replacing these is
fairly straight- forward.
Thanks for your help,
Dan
Steve Bigelow
Guest
Posts: n/a
news:55059941ee9ca9a80e6542fa3d7031b4@localhost.ta lkaboutautos.com...
> Steve,
> Dan
Not hard at all...although it does require the purchase of a slide hammer. I
think I paid about $15 for mine.
http://home.comcast.net/~em-engineering/T2T013.pdf
I managed to do all the ports without removing the fuel rail...actually
without removing anything except the port caps!
Jimmy101
42
Jan 10, 2017 07:23 PM
RubyQQ1211
Feb 10, 2011 05:14 PM
YeeFit
Aug 13, 2008 03:23 PM
andy23666
Jul 10, 2007 07:42 PM
mtoinkz@gmail.com
Oct 5, 2005 11:30 AM
