1998 Honda Accord Coupe
Old Jun 13, 2005 | 03:26 PM
kirkstinson@hotmail.com
Guest
Posts: n/a
I was wondering if anyone had some ideas on how I can get this car
started. Went on vacation last week and upon return my 1998 Accord
Coupe V6 will not start.
The battery seems to be fine and it cranks over the engine nicely. I
have checked the cables, air filter, fuel cap, etc. Any ideas?
Jason
Guest
Posts: n/a
Re: 1998 Honda Accord Coupe
In article <1118592832.648492.58170@z14g2000cwz.googlegroups. com>,
Possible causes:
defective coil
defective fuel pump relay and/or harness at relay.
defective fuel pump
Loose distributer is changing timing.
I advise you to have the car towed to your favorite mechanic or a Honda
dealership. When I was younger, I would replace items that I thought were
defective to fix problems like the one you are having. It makes more sense
to make sure an item is really defective before you replace it--it saves
more money in the long run. I should note that when I was younger--I did
not have hardly any testing equipment.
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
TomP
Guest
Posts: n/a
Check the ICM
NOTE:If the malfunction indicator lamp (MIL) comes on, refer to the Diagnostic
Trouble Code (DTC) troubleshooting Index; refer to the '98-02 Accord Service
Manual.
Perform an input test for the ignition control module (ICM) after finishing
the fundamental tests for the ignition system and the fuel and emissions
systems.
1. Disconnect the 3P connector from the distributor.
2. Turn the ignition switch ON (II). Check for voltage between the No. 2
terminal and body ground. There should be battery voltage.
+ If there is no battery voltage, check:
- ignition coil.
- BLK/YEL wire between the ICM and ignition coil.
+ If there is battery voltage, go to step 3.
3. Turn the ignition switch ON (II). Check for voltage between the No. 3
- ignition coil.
- BLU wire between the ICM and ignition coil.
+ If there is battery voltage, go to step 4.
4. Disconnect PCM connector B (25P) and check for continuity on the No. 1
terminal between the ICM connector terminal No. 1 (YEL/GRN) and PCM connector
terminal B13. There should be continuity.
5. Check for continuity on the No. 1 terminal to body ground. There should be
no continuity. If there is continuity (short to ground), the ICM is probably
damaged.
6. Reconnect PCM connector B (25P) and the distributor 3P connector.
+ If all the tests are normal, replace the ICM.
> Possible causes:
> defective coil
> defective fuel pump
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
motsco_ _
Guest
Posts: n/a
Parts don't 'fail' while you are in Hawaii. You've got a flooded engine,
because one of your injectors has taken a whole week to drain all the
fuel from the rail into the engine. Like the Owner's Manual says, hold
the pedal to the floor and crank it for up to fifteen seconds. It will
start with a puff of black smoke.
Run a couple tanks of Gasohol thru it, or some Techron injector cleaner
to prevent it happening again.
'Curly'
Old Jun 16, 2005 | 01:37 PM
Guest
Posts: n/a
After two days of trying to get the car started with a variety of
techniques, I gave up and had it towed for repair. It sat for 1 day at
the shop and cranked up fine the first try for the mechanic.
Grrrrrr....but good news all the same, no repair charges and the tow
was free.
Thanks for all of the advise!
> 'Curly'
motsco_ _
Guest
Posts: n/a
> was free.
Are you saying that holding the pedal-to-the-metal (like the manual says
for flooding) didn't make it start?
'Curly'
freaking dude
Jul 10, 2007 09:54 PM
jostorama@gmail.com
Oct 17, 2005 10:32 PM
Fijoy George
Jul 24, 2005 11:53 PM
baccus
May 4, 2005 04:44 PM
justice01812
May 4, 2005 11:16 AM
