check gas cap warning
Old Jan 24, 2008 | 01:57 PM
seizure's Avatar
2 years and 17400miles, problem free until now.
10 days ago, Check gas cap light flashes on the the dashboard computer/odometer when I start up.
dealership says just fill up with more gas, check the gas cap is on properly and wait 10 days to let the computer reset.
Well that hasn't happened.
Suggestions ?
has this happened to anyone else ?
Old Jan 24, 2008 | 02:09 PM
Hocker's Avatar
Senior Member
Check the gas cap? I put a differant gas cap on mine because i had the mugen gas cap cover on it.
Old Jan 24, 2008 | 02:29 PM
RichXKU's Avatar
I got this once as well for no apparent reason. With the car off I just removed the gas cap and put it back on hulk style. It cleared a few days later before the next fillup.
Old Jan 24, 2008 | 03:53 PM
can't you just reset it using a OBD2 scanner?
Old Jan 24, 2008 | 09:53 PM
seizure's Avatar
gas cap
Don't know what an OBD scanner is.
The dealership says they can reset it but doing so may delete any other warnings that "maybe" was about to happen like e.g. the check engine light.
I was wondering if the cap was faulty ( air leak) and hence the question to you out there asking if the same problem has hit others.
Incidentally I put on the gas cap just like any regular person would .. snug / click stop.
Will give it another week and take it in if it still persists.
Many thanks for the feedback so far.
Old Jan 24, 2008 | 11:13 PM
SpoonSportFit's Avatar
isn't that the same scanner they plug up at autozone and places like that? couldn't you run a diagnostic and have a full list of could be problems.
Old Jan 24, 2008 | 11:20 PM
doctordoom's Avatar
Supervillain
i think with the scanner you can selectively delete specific check engine codes that show up. correct me if i'm wrong though. but if that is true, then you can delete this code and not worry about deleting any potential real problem codes that were about to show up.
Old Jan 27, 2008 | 10:26 AM
seizure's Avatar
happy ending
I had a honda locking gas cap which I had not used.
i replaced the original cap with this and the warning "check gas cap" has disappeared !
just to find out whether this was the deciding factor or it was just a length of time as the dealership seemed to suggest, i have put the original back on. Let's see if the warning returns, which might suggest a cap problem ?
will keep y'all posted.
many thanks for all your helpful comments.
MaidenJapan
Nov 19, 2016 04:29 AM
Gra-fit-e
Mar 30, 2013 10:18 PM
ketchup1
Sep 13, 2012 09:42 PM
ztyhurst
Jul 8, 2012 09:06 AM
vickenp
Oct 26, 2011 08:55 AM
