Seatbelt Light and Beep
Old Jan 30, 2008 | 08:20 AM
MiniMeRR's Avatar
Anyone know how to turn off the seatbelt light and beep?
Old Feb 17, 2008 | 07:37 PM
space cowboy's Avatar
put on your seatbelt
Old Feb 17, 2008 | 07:48 PM
billmus86's Avatar
My Lips Bigger!
if your too cool to wear your seatbelt ..
try buckling it and then getting it
but dont blame me for telling you that
Old Feb 19, 2008 | 09:34 AM
MiniMeRR's Avatar
Cool but no thanks.
Old Feb 19, 2008 | 11:23 PM
mkx-r's Avatar
Personally I'd like to know the answer to this myself. I was recently transporting a bunch of 2x6 gridwall panels, with the passenger seat laid back flat. The panels were heavy enough to trigger the switch and make the puter think there was someone sitting there, hence resulting in the ever-annoying beep. Had to reposition the panels to plug in the seatbelt on the passenger side in order to avoid a very 'beep'y 40 minute ride to work. Sometimes safety features like this can get in a way of the usability.
Old Feb 20, 2008 | 11:29 AM
MiniMeRR's Avatar
Very well put, Thats what am talking about that was the main reason that I wanted to know how to diconnect it cause had a box in the passanger seat and had my seatbelt on and then all of a sudden that dam beep went off and was like the hell thought it was broken until I looked under the seat and saw the passanger seat has the same dam sensor. lolol.
Old Feb 20, 2008 | 12:03 PM
mkx-r's Avatar
Strangely enough, on the same day described above, I also got a light that the side airbags were disabled. I'm guessing it's due to the fact that there was some heavy cargo present, but since it didn't even reach the window line, side airbags should have remained active. There are times when I transport light but large cargo, (20cu.ft. bags of packing peanuts, I can fit 2 of those in the back, plus some boxes), and that basically fills up the cabin to the roof. In times like that, the side bags still remain active, and they probably shouldn't.
I suppose a quick solution to the seatbelt issue would be to get one of those latch inserts by itself (from junkyard, or maybe auto-parts store), and just insert it into the passenger seatbelt latch to gently fool the system. That would have drawbacks, as it would keep the pass/ airbag active as well, and deploy it uneccessarely in case of an accident. Perhaps the next-gen fit should have a 'cargo' button (momentary pussh-button), which would tell the computer there is no passenger in the front, only cargo, so no need for seatbelt, or the airbag. The mode would reset to 'passenger' automatically when the engine is turned off of course, for safety reasons.
Old Feb 20, 2008 | 12:27 PM
TOOL's Avatar
SEARCH!
We have many many BIG threads on this.
Tyler
Old Feb 20, 2008 | 02:36 PM
MiniMeRR's Avatar
Originally Posted by TOOL
SEARCH!
Tyler
Did!
And did'nt find anything? Little help would be nice or is it too much to ask?
Old Feb 20, 2008 | 10:08 PM
you could un-plug the weight sensor from under the seat if you can figure out which one it is
Old Feb 20, 2008 | 11:21 PM
jdjohnson9's Avatar
One of my friends has a civic and wanted the same as you guys. All he did was bought just the buckle itself and puts it into the latch. When he doesnt need it he pushes the button on the latch, puts the buckle in the glove box and then uses the seat belt itself. It takes 2 seconds to do and no wierd wiring or anything to mess with. That will take care of your problem.
Old Feb 21, 2008 | 11:03 AM
MiniMeRR's Avatar
Yea looked under there last night and theres three plugs Might try disconecting one by one and see what happens.
MiniMeRR's Avatar
This is my second choice if I don't find a way to do it with out disconnection the side passanger air bag or mine, thanks
Old Feb 21, 2008 | 07:40 PM
BlackCobra's Avatar
the only problem with this is that if you were to get into an accident then the air bag on the passenger side would deploy unnecessarily. But i guess that is something that doesnt matter.
Old Feb 22, 2008 | 02:57 PM
MiniMeRR's Avatar
Yea was thinking of that too, but if all I have to do is remove the buckel it could have been a defective airbag don't think they would ever find out. And I've see passanger airbags go off from a hard enought hit so you never know. We'll see still looking gonna try some different ideas this weekend and see what happens.
Old Mar 2, 2008 | 01:54 AM
lidoshorty02's Avatar
i unpluged the driver side seat belt sensor but then the airbag light goes off so i guess the only safe way is gettin a buckle. n e other ideas i hav racing harness and want 2 kno 2
Old Mar 2, 2008 | 02:16 AM
When you un-plug the sensor your Fit will think that no one is in the seat. Best bet I would go with jdjohnson9's suggestion get an extra buckle and use it as needed.
Old Mar 3, 2008 | 11:45 AM
MiniMeRR's Avatar
Well trying out the different plugs under the seat right now and seeing what happens.
But the way things are going looks like am gonna have to buy just 2 buckels lolol.
Old Mar 3, 2008 | 09:40 PM
Thats one way to go, but your airbags still wont work.
Old Mar 4, 2008 | 10:07 AM
MiniMeRR's Avatar
Thats what am doing now is trying different combinations under the seat so that the airbags still work.
