CF Hood Install Advice
Old Jan 31, 2008 | 02:22 PM
Crucio's Avatar
Hey guys,
i just got my mg style hood today.
Any advice or tips on installing?
thanks!
Old Jan 31, 2008 | 02:53 PM
kelsodeez's Avatar
UNBANABLE
not really. mine bolted on really nicely. although, i dont know what kind of hood you got (mine was a seibon) but if you have to drill holes in it to make the stock rubber and heat sheild fit, make sure to measure twice, drill once.
are you going to be using hood pins?
Old Jan 31, 2008 | 03:02 PM
Crucio's Avatar
i've got a seibon also, the packaging was amazing, too me about 45 minutes just to get the thing out of the box.
i do not plan on using any hoodpins yet, maybe in the future.
did you have to drill holes with your seibon?
Old Jan 31, 2008 | 03:26 PM
kelsodeez's Avatar
UNBANABLE
yea i drilled a few holes so the rubber strip on the inner front lip would pop into place and a few more holes for the heat shield. i also went down to honda and got the stock stickers for the inside. also, there were indentations where the holes should have been. DO NOT USE THOSE! they dont match up to where the holes really should be. measure yourself and make a template. and dont drill through the hood. just through the fiberglass on the inside =)
Old Feb 9, 2008 | 02:54 PM
goodyonsen's Avatar
do you have to put all the stock stuff back on like the heat sheild and stuff?
Old Feb 9, 2008 | 02:59 PM
kelsodeez's Avatar
UNBANABLE
you dont have to, but i highly recommend it.
although, you do have to put the rubber stripping on the front lip of it otherwise you will get all sorts of water in your engine bay in the rain.
Old Feb 10, 2008 | 05:13 PM
Crucio's Avatar
I was looking at the heat protectory under the OEm hood, i have the seibon MG style hood with the vents, wouldn't the vents get blocked if i put the heatprotector?
Old Feb 10, 2008 | 06:01 PM
kelsodeez's Avatar
UNBANABLE
i havent seen the mg style hood in person, but my advice to you is, if the heat shield is covering the holes, go to the dealership and get a new one, then make a template of where the holes are, cut out some holes in the old one so you still have an uncut one for your stock hood. also, pick up some oem stickers that go on the underside of the hood to give it that little extra atention to detail.
bottom line is, if you dont have a heat shield, the clear will lift and discolor on the cf hood. ive seen it happen on a spoon hood for a civic.
Cat
May 9, 2010 12:59 PM
Gucci
Sep 30, 2007 09:37 PM
i-Fit
Jun 26, 2007 10:57 AM
actonimpulse
Jun 15, 2007 02:16 PM
Jimmy101
Jan 13, 2007 02:19 PM
